I don't think there is an "official" CF wraps DIY. Taking the console panels off the car for wrapping is very straightforward. Here are a few pointers to take things apart for CF wrapping.
To remove the radio console panel:
1) Pry on the edge of the radio console panel to pull the panel off. Pressure clips hold the panel in place. Trim removal tools like these from Harbor Freight will comes in handy,
http://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html
2) Disconnect two wire connectors on the back of the panel and its free from car.
To remove the shifter console panel:
1) Apply the parking brake. Shift the car to Neutral as it is the easiest to work the panel off. Make sure you put on you parking brake when shifter in Neutral.
2) Slide the shifter boot down to expose a silver metal spring clip that holds the shifter knob in place. Simply pry with a small flat head screwdriver, slide the clip off and take the shifter knob off the shifter.
3) Pry from the back end near the armrest and work your way to the front to take the shifter console panel off. Again the panel is hold in place with pressure clips. Once it loses, lift it up and disconnect the seat heater, hazard light switch, and the shifter indicator light connections to free the console panel off the car.
4) Once the shifter panel off the car, undo four screws on the backside of the chrome shifter panel/boot hold it onto the console panel. Out the shifter back to Park if you like. Yes you still can shift the shifter without the shift knob in place.
5) Undo a few more screws to take the storage compartment out of the shifter panel. It is easiest to wrap each piece individually.
To remove door handle aluminum piece, just pry from the bottom of the piece and it should come right off the handle.
The wrapping:
1) A hair dryer, small sharp box cutter and scissors are basic tools when doing CF wrapping.
2) Cut out a piece of CF large enough to cover the piece.
3) Peel the backing off, lay it on the center of the piece and work your way outward and push out all air bubble as you go.
4) When it wrapping around the corners and edges, soften the CF with the hair dryer enough, wrap it in place and hold it a bit for it to from the shape as it cool down.
Reinstall:
The reinstall just the reverse of what removal
. Only special attention needed was the red/orange indicator in the chrome shifter panel. Just make sure the red/orange indicator is pointing to whichever gear position you left it (Neutral or Park). Slide red/orange indicator on the backside of the chrome shifter with your finger if it happens to miss-aligned.
Hope this helps.
