Just called my Infiniti dealer to get some pricing.
Please tell me your thoughts...I'm at 53k miles, but will be at around 55-56k at time I may do some of this since I will be doing lots of driving the next week going to Wisconsin and such.
Front brake pads - $99, labor - $226 (They said rarely do they even see someone change both at the same time because I was inquiring both)
Rear brake pads - $89, labor - 226
Brake fluid flush - $163 (They say I probably don't need this but figured I might if I end up changing both brake pads)
Injector/throttle service - $176 (I guess this one takes about 1.5 hours and they run it through a pressurized system with a strong cleaner that cleans the fuel injections, throttle body, etc - they recommend this every 30,000 miles).
There is a local shop that could do this for a fraction of the cost, but thoughts on if you think there are certain steps that our 2nd gen Infiniti FX maybe has that maybe someone who works with domestics all day may not know and screw up? Basically, if it's the same exact then I can just get it done at the local, but if it is a little different I probably wouldn't want to risk a screw up or a bad job causing issues later or worse braking or something.
