So back in January was getting
VCD Off SLip and brake lights.
Turns out my rear brake pad needed replaced. I suspected a bad caliper also since 1 side was way off the other side.
Yesterday started hearing a screeching sound like time to change the brakes.
Today I remove the tire. Pads looks like fine I go ahead an replace the caliper. Sound not only there but sounds worst.
If i put in going forward with no gas applied normally it would coast forward at idle speed now it just stays still.
If i put it in reverse does the same thing.
Here is the current sounds.
https://youtu.be/oNW443Fb3ZU
Car is unusable as is.
Please give ideas where to go from here.
