Fire0nic3FX
My G35 sedan only overheats when I turn the AC on while idling or in very slow traffic. The needle for the temp goes all the way up to high. If it turn it off the temp goes back down. The only time it ever overheats is when the AC is on only. Also when it does start to overheat the AC then begins blowing out hot air only.
Now here is where I'm confused. Coolant level is fine and no air bubbles and just had a flush a few months ago so everything is clean.
I'm wondering is the electric fans suppose to both be coming on when the AC is on? Only the driverside fan comes on then it goes off after a few seconds. The passenger side never comes on at all. Also I notice if I'm idling and the AC isn't on, the fan that does work keeps on kicking on every minute and even then only one fan comes on. I was aware of the issue when I bought it so I'm just now getting to it. Also I noticed if I turn the AC on it takes forever for the one fan that does work takes a few minutes to kick when it realizes the AC has just been turned on.
does it look like its the fans? I will buy them but I don't wanna waste money on it if it doesn't fix the issue.
