So I've been hearing that the new G37 engine is the same as the 09 fx35 engine.
I'm DIEING to mod this thing, something! ...so I did a little research for a little ol' intake...here's what I got...
So that's a 09 g37 STOCK.
That's a 09 G37 with a brand new month old Injen Intake...Injens main site says it can also be a CAI.
So here's a 09 FX35...
Now, check this out..
First thing's first - just as you'd expect, the higher number in the G37's name denotes a larger displacement engine. The 2007 model's VQ35 3.5-liter has been stroked to 3.7 liters. The new engine, dubbed VQ37VHR, now has an 86-mm stroke (up from 81.4 mm) and a compression ratio that is, at 11.0:1, four-tenths of a point higher.
**The biggest news about the engine, however, is that it is the world's first application of Nissan's VVEL (Variable Valve Event and Lift) technology. Like BMW's Valvetronic, VVEL eliminates the need for a conventional throttle butterfly, controlling engine output by continually and steplessly varying valve lift and timing. The V-6 retains a conventional throttle butterfly, but it's used for emissions-related purposes only, according to Nissan.
By having infinite control over both valve lift and timing, Nissan was able to flatten the VQ's torque curve at both the bottom and top of the rpm range. The result is that while the 3.7-liter's 270 lb-ft peak torque is only 2 lb-ft higher than the 3.5-liter's, the curve shows improvements of about six percent down low and four percent up high.
The increase in high-rpm torque results, of course, in more horsepower. The G37 is preliminarily rated at 330 horsepower. And as a result of VVEL, it should beat the 3.5-liter's EPA fuel economy ratings. Now that's progress.
Nissan says that, compared with BMW's Valvetronic, VVEL is 32% quicker to respond, 20% smaller, and uses 52% less parts per cylinder. It also allows the engine to rev higher - the 3.7-liter is redlined at 7,500rpm.
The G37 will be available with a 6-speed manual transmission (6MT) or a 5-speed automatic. 6MT and sport-pack automatics, like the test mule we drove, will have limited-slip differentials.
Even with the automatic, we noticed no throttle lag from the VVEL. Indeed, the throttle was precise enough to help us do exactly what the G Coupe loves to do best - fantastic power-slides.
hmm...
So the engines are different after all?
2009 Infiniti FX35 Specifications
FX35 Engine Performance & Fuel Economy
3,498 cc 3.5 liters V 6 front engine with 95.5 mm bore, 81.4 mm stroke, 10.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35DE
Premium unleaded fuel 91
Multi-point injection fuel system
23.8 gallon main premium unleaded fuel tank 19.8
Power: 226 kW , 303 HP SAE @ 6,800 rpm; 262 ft lb , 355 Nm @ 4,800 rpm
2008 Infiniti G35 Specifications
G35 Engine Performance & Fuel Economy
20.0 gallon main premium unleaded fuel tank 16.7
Power: 228 kW , 306 HP SAE @ 6,800 rpm; 268 ft lb , 363 Nm @ 5,200 rpm
That's an 08 G35 engine...
Will it work ?
What do you guys think?
-MAFs
hmm...
Will it work ?
-MAFs
