roadracer516
- Salt Lake City, UT
I cannot tell with the wheels on if the pads slide out the front of the caliper without having to remove the calipers themselves. Does anyone know? Thanks in advance!
most brembo/akebono designs dont require removal of the caliper themselves. I looked at a FX50 brake system but i dont recall 100% but i'm willing to say its no different from a brembo caliper as the viewing window of the pad is the same and the slot is large enough.
The FX50 Akebono uses fixed calipers. Just gotta deal with sliding pins and clips
But don't you need to press the piston back in because the new pads will be much thicker. How do you do that without removing the caliper off the rotor?
actually you will need a c clamp, when i worked on my friends 6 piston brembo it was really hard for me to press it back with a flat head screwdriver. Also sometimes one side of the piston goes in or compresses the other side comes out ( referring on the same caliper your working on). You got to do it slowly on eachm piston head
Jonas, I'm surprise that your bleeder screw caps are dried out already. http://shop.advanceautoparts.com/we...chTerm=bleeder+screw+caps&searchedFrom=header
Hey roadracer, did you remember to lube up the sliding pins before putting them back on? They are a PITA to take out if not lubed. What pads did you go with?
jdTrader - It is recommended to change rotors every 2 pad changes unless the rotor has issues. Most people just change them both because of convenience
I think its very hard to beat OEM pads especially a akebono/brembo OEM pad in terms of bite. On the g35 with brembos many went with project mu. But that's mainly due to price.
Dust is another story, its a by product of your pads actually doing a good job.
TapaTalking
