There was going to be a further confusion, and I was about to be sent another wrong part, all this time infinitipartsusa was talking about the idler pulley - the serpentine belt stationary pulley, while I was talking about the auto tensioner pulley, I think it was not a glitch, it is a rather bigger flaw that reflected in in the drawings as well. I may have contributed to that by calling it idler pulley too but that was in the aftermath anyway. Finally, after having a clarity, the pulley I need can not be sold separately, the immediate higher assembly is the entire auto tensioner assembly for 94$, which is too much for just a bad bearing and low quality pulley.
After all of that, I decided to buy either ACDelco or Gates pulleys, they can not be lower quality than the OEM after what I have seen, and do not "wobble", they are 20$ each.
Sent from my iPad using
---------- Post added at 04:25 PM ---------- Previous post was at 04:13 PM ----------
Too bad the machine shop distorted the pully! They could have applied a little heat from a propane torch to the outside of the pulley before starting the press out! How much did you pay for the new bearing vs. the whole wrong assembly from Infiniti parts usa? Save the new bearing for the next time you have to fix the tensioner! I am guessing you dont have a Infiniti dealer close to your location?
I should've done that, but now that is done, I feel if I try it again it will ruin the pulley, it took too much already. The bearing was only 3$, vs 94$ for what I would get from infinitipartsusa.
We do not have dealers specifically for infiniti in the entire country, there are shops which sell infiniti genuine OEM parts, but, they have only basic items in stock (filters, spark plugs, belts, bulbs ...etc), anything else they need to get it from Dubai, it takes 3 weeks after upfront full payment is made, and it comes very expensive. So it will be more expensive than me buying from infinitipartsusa. But with a good bearing job like you suggested it will only cost 3$.
---------- Post added at 04:28 PM ---------- Previous post was at 04:25 PM ----------
So their glitch became your problem? That's not right, they should send you the right one for free. Lesson learned for them. Ya those pulling aren't strong enough to press out the bearing and I think they use some type of adhesive to keep them in. Been there done that, I just buy a new pully and call it a day.
Sent from my SGH-I747
They offered the following: if shipping them back is more expensive that the wrong parts, they will refund and I keep them.
