IvoRoyfx35
- Cerritos, California
I've been meaning to detail my ride for some time now, but never got around to it because I've been busy detailing my customer's cars. Well, I finally decided to save a weekend for my fx and give it a good spa treatment. But first, I had some long scratches on the hood when I bought it, so I decided to work on that. I'll share my procedures in case someone finds it helpful/useful. Here are some of the scratch pics.
I first tried hitting it with Meguiars #105 on Purple Foamed Wool pad, using my makita. This was pretty agreesive, but I was only able to remove what looked to be about 50% of the scratches. So, I decided to wet sand the area (about 1/4 of my hood) using a 2000 grit sandpaper. Then, I buffed off the sanding marks with 3M Rubbing Compound using Yellow Wool pad (makita), followed that with Menz Intense Polish on Meg W7000 pad (makita), and finished off with Menz Final Polish (PO85RD) on LC white pad using my pc. Here is the hood with the scratches removed.
The rest of the car only needed very minor swirl correction, so after claying, I used the Menz combo (Intensive Polish on Makita + Final Polish on PC). The entire car was then sealed with Chemical Guys M-Seal and after proper curing time (8 hours), I applied a coat of CG carnuaba paste wax. For the plastic trims, I used mother's back to black. Chromes were polished with Meguairs chrome polish, and the tires received 4 different tire dressings. Here are some after pics.
I wanted to take it for a drive and take some pictures, but was too tired and decided to call it a day. Hope you guys enjoy the pics!
P.S. As mentioned, I wanted to tested out some of the popular tire dressings on this detail, so I used different tire dressings on each tire. That write-up/pics will come later as I will be continually checking & taking pics for shine/depth and durability.
