Seems like I am struggling with wheel sizing fitment issues, like several folks on here, when ordering wheels online. I am attempting to go to a 22" wheel, replacing my OEM 21x9.5" with +50mm offset wheels. I am trying to go a bit concave, clear the hub, avoid rubbing (especially in the front w/ a BBK on the FX50), push outboard somewhere between 20-25mm on all 4 corners, and go as wide as possible with a square stance. At this point, I have located some new wheels that come in a 22x10.5" variety with both a +42mm and +25mm offset. They also come in a 22x9" variety with similar offsets, but for the stance I am trying to achieve, I selected the 22x105" with +42mm offset. Here are my calculation results with a 285/40r22 and 295/35r22 setup, my questions follow:
http://www.rimsntires.com/specspro.jsp
http://www.willtheyfit.com/
Questions:
So my biggest concern is on the front-end where the BBK lives - can it be cleared with these wheels? Next, the hub stub ends - will I need to get a hubcap extension (prefer the flush cap)? Next, suspension components - is the 2-5mm calculated inboard difference likely to hit anything? Finally, I'd prefer the 295/35r22 tires - rubbing issues on the inner fender possible (I intend to drop with H&Rs down the road)? Thanks for the input in advance.
Questions:
