You can use a hair dryer but it will take a bit longer to heat up . I got a Wagner heat gun from home depot for $25 and it works great . I added the link below . if you do get the gun leave it on low setting not hi . it will warm up in a second . Few notes before you start .
1. The clock trim holds the whole dash it you have to remove it first. put your hand on the left and right side and pry it up word. Also open up the cassette cover as it rubs up against it if its closed and wont allow you to take it out.
2. The clock trim is held with 2 screws take it out so you can wrap it .
3. For best result after you remove the middle console there are 4 screws holding the ash tray assembly in place and 4 screw holding the cup holder and 3 screws holding down the shifter . All these have to be removed .
4. if your wrapping the shifter take it from me and don't try to cut out the P R N D . I tried 4 times and wasted so much wrap . Plus under the Tach it shows you where your shifter is so I wouldn't worry about it.
5. the cup holder has to completely come apart and this is a pain . There are 4 plastic legs holding down the button and you will have 2 springs under the button and 1 that pushed against the cup holder lid.
6. cup holder lid was a paint to take out also as you had to remove the spring that keep it open . one screw on the left just holds the cover and the other holds down the cover , plastic locator , spring lock & spring . remove the screw . there is a round spring lock . once you take that off the plastic locator & spring will come out . to put It back together . Screw the side with no spring first . then close the lid and put in the spring , plastic loacator and spring lock . now using your hand or a small flat head push down on the plastic locator and turn it. keep turning it till it seats and with the other hand put the screw in . you have to do this in once shot. If the lid doesn't stay open then you have put it in backword try doing this again in the open position .
7. make sure you don't close the hole on the lid or it wont stay closed.
http://www.homedepot.com/p/Wagner-HT1000-1200-Watt-Heat-Gun-0503008/100048744
