mbarb15
- Lyndhurst, NJ
on my first gen I have installed new rotors and pads, r1concepts and I'm experiencing squeal and grinding when coming to a dead stop, no vibration or warped rotors, could it be the pads? Ceramic r1concept
You did the bed-in procedure?
Which R1 rotors do you have?
I can't speak for R1 pads. My previous StopTech ceramic pads does not squeal but didn't last me that long. I would say try Akebono ProAct Ultra Premium Ceramic brake pads. So far I am happy with its performance. BTW, OEM pads will always squeal regardless of it being old or new.[h=1][/h]
what pads? i have r1 drilled sloted with hawk pads. no squeal
Can you see score marks on any of the rotors?
you either installed something incorrectly or you need wait a little longer for the pads to break in
They're not OEM pads, they're a packaged r1concept deal with Eline rotors and r1concept ceramic
Pads
I believe the R1 ceramic pads that you recieved are actually Centric Premium Ceramic pads. These pads are not really good. Lowest Centric pads I would go is the Posi-Quiet ceramic. The premium ceramic that I think you received are for "economy", not for daily driving. Meaning lower end.
Also, did you make sure you put synthetic grease on the pins, and brake lub on the back of the pads? Hopefully the grinding noise you are hearing is not a stuck caliper.
Did you grease the backsides of the pads? I grease anywhere the pads slide. This includes where the pads slides within the caliper.
yea, everywhere there's movement... good quality synthetic brake lube too..
I have always used Hi-Temp wheel bearing grease.yea, everywhere there's movement... good quality synthetic brake lube too..
try to re bed them one more time.. 4 times go 60mph brake hard till 40mph, then 2 time from 40mph to 10 mph; after all this let the car sit at least 15mins to cool off
