Ataher
- Tripoli - Libya
Shortly after I start the car and start driving, the flat tire signal turns on although none of the tires are actually flat, when I turn the engine off, and then turn in on again, the signal turns off, and so on.
When I check which tire is flat in the navigation screen, I see that the 2nd sensor reading is **. I understand the 2nd one is for the front right tire pressure sensor, so I swapped tires around many times but the 2nd sensor reading remains the same as **. I understood from this the issue is not related to any of the sensors in the tires and rather somewhere else. .
Any one might have encountered the same issue? And how this can be diagnosed and fixed? I am not sure if my analysis above is correct.
Sent from my iPad
Sent from my iPad
