Fire0nic3FX
Summary of ITB12039:
IF YOU CONFIRM: * The steering column comfort adjustment features (tilt and telescopic) stops working. * The vehicle is not subject to previous ITB09-014 NOTE: If vehicle is eligible subject to previous ITB09-014, this bulletin does not apply. ACTION: * Replace tilt and telescopic motors only. Do not replace the column assembly. Please see this bulletin for further detail.
Basically this was an issue before with the FX about the steering wheel comfort adjustment motor being made out of spec and failing and there was a TSB on it found here:
https://www.infinitiscene.com/searc...FX-Steering-Column-Comfort-Adjustment-Failure
However this TSB I just posted has nothing to do with the old TSB. Apparently the motors they replaced them with before can fail again. I had mine replaced before on the old ITB09-014 bulletin cause it just stopped working all of a sudden. Common issue on the 2nd gen's. Now there is a new TSB ITB12039 to replace the motors again cause they may fail again.
