- Toronto, Canada
- 2008 fx35 AWD
hey guys so i picked up a used set of fx headlights. im looking to customize it slowly when i got time. the thing that is stopping me is wiring... not sure how to wire it up without messing anything up so here goes.
option1
i want to put the stock fx projector where the dtrl is and make it hid by hacking the back of the headlight. is there a way to wire it up so both the hid projectors can be controlled together and turns on when it calls for them automatically? also can i get the leveling motor to work also?
Next thing i want to do is install halo lights. two white ones on the inner 2 headlights, then a red (if it complies with the law) or orange one on the turn signal one. These 3 halos would be used as dtrls.
getting these halos or extreme designs led ones
http://www.ebay.ca/itm/03-07-Infini..._trkparms=algo=LVI&itu=UCI&otn=3&po=LVI&ps=63
Option2
install stock projector in dtrl location but just use a dtrl led bulb so i dont gotta hack the back of the headlight. Then do the same thing as option1 but halos will be on with the dtrl.
what would i need to make this happen?
option1
Option2
