- Dallas, TX
- 2007 FX35 RWD
Long story short, my ECU ended up with a different ROM on it, and UpRev doesn't have that old ROM, 8Y71A, which I believe is only on 2007 FX35's with ICC. Not sure if AWD or RWD matters.
What I need is to find someone else with the same ECU ROM. To do this, I think the best way is to go to an UpRev approved shop who can then connect the Osiris software to the ECU and check if it has the same ROM I need and then they can dump the files to send to UpRev. And at some point hopefully UpRev will modify them and I can get my ECU reflashed to the correct ROM.
If you go here, you can see if there's a dealer close to you: http://www.uprev.com/dealers.php
Thanks to anyone who thinks they can help. I would recommend calling the shop beforehand to make sure they can do everything. If it's a long drive, I will be happy to PayPal a little money to help cover gas.
