Fire0nic3FX
Just thought about starting this thread and keeping it updated with our milestones for 2nd gen people only. This is in no way related to the mileage thread on here. This will have some good references for people in the future. Put down any problems, expenses, etc etc you've dealed with on your 2009+ FX35/50. Also put down the miles your currently at so we know.
2009 FX 36,500 miles as of 7/16/2011:
1. Driver and passenger side view mirrors wobbling and rattling. I found a DIY on here and tighten the 3 hidden screws and the bottom of the mirrors and the problem went away.
2. Center console squeaking. I found a DIY and took the console apart myself only to find the AC cooled seat switches rubbing up against the shifter panel. I applied felt tape in between and the noise went way.
3. Rear seats kept making rubbing noises when reclined. Applied leather conitioner and noise went away.
4. Popping noise from lower windshield area when going over bumps. Found outside windshield cowl was clogged with dirt and rubbing up against the windshield. Cleaned windshield cowl, installed it back on and noise went away.
5. Gas lid door wouldn't lock when alarm is set. Dealer looked at it and found out it had never been programmed. They used the Consult III machine and programed it and it now works.
6. Catalytic Converters making a ticking noise while idling. I'll get that looked at again when I go back to the dealer.
7. Brake popping noise when parking. I'll also have the dealer look at that when I go back in.
8. Steering wheel tilt and telescoping function stopped working. Dealer replace steering wheel comfort adjustment motor per TSB.
Everything has been pretty reliable so far. Just those little annoyances as I mentioned above. No big deal though since I really didn't have to make any trips to the dealer to do it. I've spent $0 on the FX so far since I'm still under warranty obviously. Only maintenance things I paid for like the tranny fluid, differentials, transfer case fluid, wipers, filters, and motor oil changes.
