This is a pretty basic DIY but you can't replace the blade in position so I had trouble figuring out how to do it until I saw an exploded Parts view (thanks to Fire0nic3). So I thought I would show how to do, it is very simple once you realize what to do.
First you need a new Rear Wiper, Here's the Part#
Start with the rear wiper in the auto stop position, and remove the wiper arm cover
This will expose the wiper arm mounting nut. Remove the nut with a 10mm socket
Pull the wiper arm off the splined shaft
Now you can easily remove and replace your wiper blade with the new one.
Reinstall in the reverse order.
