F
Fire0nic3
Guest
So I hit a milestone in my 2009 FX today. It hit the 30K mark
No problems at all with the car! Car is bulletproof so far
Going in tomorrow morning for my 30K service:
Mobil 1 EP Synthetic Motor Oil Change
Tire Rotation
Front differential oil change with Nissan Hypoid Gear Oil 80W-90
Rear differential oil change with Nissan Synthetic Gear Oil 75W-90
Transfer case oil change
4 wheel alignment
When you change the transfer case and front and rear differential oil, you must change both the drain and refill gaskets on the plugs. Never reuse them. I'm going to make sure to remind the service advisor about that in the morning. Changing these are required at 30K only if you tow or have the tow package, or drive on rough muddy roads.
Things I did myself (too easy):
Cabin filter changed
Engine air filters both changed
Lubed all locks and hinges
Tire Rotation
4 wheel alignment
