2003-2008 FX35 / FX45 OUTER TIE ROD REPLACEMENT
TOOLS:
SOCKETS
SOCKET WRENCH
TORQUE WRENCH
ADJUSTABLE WRENCH
BALL JOINT SEPERATOR
SAFETY:
ALWAYS USE QUALITY JACKSTANDS WHEN WORKING UNDER YOUR VEHICLE.
NEVER WEAR LOOSE FITTED CLOTHING AROUND A RUNNING MOTOR.
ALWAYS WEAR SAFETY GLASSES.
PLEASE STAY SAFE.
1. TURN YOUR WHEEL SO THAT IT FACES THE OPPOSITE SIDE OF THE WHEEL YOU ARE WORKING ON.
2. RAISE YOUR CAR AND PLACE ON JACKSTANDS.
3. REMOVE YOUR WHEELS.
4. LOOSEN THE TIE ROD LOCK NUT.
5. REMOVE THE COTTER PIN FROM THE TOP OF THE TIE ROD BALL JOINT.
6. LOOSEN THE BALL JOINT NUT (DO NOT FULLY REMOVE THIS NUT YET).
7. USE A BALL JOINT SEPARATOR AND POP OUT THE BALL JOINT (THE BALL JOINT IS SOMEWHAT TOUGH TO REMOVE). AS YOU TIGHTEN YOUR BALL JOINT SEPARATOR THE BALL JOINT WILL EVENTUALLY POP OUT PRETTY FORCEFULLY….THIS IS WHY WE LEFT THE NUT ON.
8. COMPLETELY REMOVE THE NUT AND POP OUT THE BALL JOINT (OUTER TIE ROD).
9. NEXT REMOVE THE TIE ROD COUNTER CLOCK WISE. (IT IS VERY IMPORTANT TO COUNT HOW MANY FULL TURNS IT TAKES TO REMOVE THE TIE ROD)!!
10. TAKE YOUR NEW TIE ROD AND SCREW IT ON THE SAME EXACT AMOUNT OF TURNS IT TOOK YOU TO REMOVE THE OLD TIE ROD (THIS WILL HELP KEEP YOUR ALIGNMENT CLOSER TO SPEC).
11. POP YOUR OUTER TIE ROD BACK IN AND TIGHTEN THE NUT AS FAR AS YOU CAN GO BY HAND WHILE PUSHING UP ON THE BALL JOINT. TAKE YOUR TORQUE WRENCH AND TIGHTEN THE NUT TO 63 FT/LBS.
12. TIGHTEN THE TIE ROD LOCK NUT.
13. PUT IN THE NEW SUPPLIED COTTER PIN (ALWAYS USE A NEW COTTER PIN).
14. PUT YOUR WHEELS BACK ON.
15. GET AN ALIGNMENT (MY ALIGNMENT WAS ACTUALLY STILL GOOD, BUT IT IS RECOMMENDED TO ALWAYS GET AN ALIGNMENT WHEN MESSING WITH STEERING COMPONENTS).
16. DONE.
TOOLS:
SOCKETS
SOCKET WRENCH
TORQUE WRENCH
ADJUSTABLE WRENCH
SAFETY:
PLEASE STAY SAFE.
16. DONE.
