PLEASE CLICK THE "THANKS" BUTTON IF YOU LIKE THIS DIY!
VQ35DE (FX35) SEA FOAM TREATMENT
MATERIALS:
SEA FOAM (16 FL OZ / 1PT)
¼” VACUUM LINE
TOOLS:
10MM SOCKET (IF YOU STILL HAVE YOUR PLASTIC ENGINE COVER ON).
SAFETY:
ALWAYS USE QUALITY JACKSTANDS WHEN WORKING UNDER YOUR VEHICLE.
NEVER WEAR LOOSE FITTED CLOTHING AROUND A RUNNING MOTOR.
ALWAYS WEAR SAFETY GLASSES.
PLEASE STAY SAFE.
CRANK CASE (OIL):
RECOMMENDED -> 1.5 OZ PER OIL QT. X (FX35 5 QTS) = 7.5 OZ OF SEA FOAM
AMOUNT USED = 1/3 BOTTLE (5.33 OZ) FOR PROCEDURE.
1. REMOVE YOUR OIL FILLER CAP AND POUR IN 1/3 OF THE BOTTLE (OR THE RECOMMENDED AMOUNT).
2. DRIVE YOUR VEHICLE FOR A MINIMUM OF 30 MINUTES/MILES, MAXIMUM OF 100 MILES.
3. DRAIN YOUR OIL AND CHANGE YOUR OIL FILTER, REFILL WITH THE PROPER AMOUNT OF OIL.
FUEL TANK:
RECOMMENDED -> 1 OZ PER GALLON
1. POUR 1/3 OF THE BOTTLE INTO YOUR FUEL TANK (OR THE RECOMMENDED 1 OZ PER GALLON).
2. THAT’S IT.
INTAKE MANIFOLD PLENUM:
RECOMMENDED -> 1/3 BOTTLE
1. REMOVE YOUR PLASTIC ENGINE COVER IF YOU STILL HAVE IT ON.
2. START YOUR CAR AND LET IT WARM UP.
3. SHUT THE CAR OFF AFTER IT HAS WARMED UP.
4. REMOVE THIS RUBBER NIPPLE COVER.
5. CONNECT YOUR VACUUM HOSE.
6. RESTART THE CAR.
7. HAVE SOMEBODY REV YOUR ENGINE WHILE YOU SUCK UP THE 1/3 OF SEA FOAM, YOUR ENGINE MAY DIE ON YOU, IF SO START THE CAR AND FINISH THE REST OF THE SEA FOAM.
8. AFTER YOU SUCK UP ALL 1/3 OF THE SEA FOAM SHUT YOUR CAR OFF AND LET IT SIT FOR 5 MINUTES.
9. REMOVE THE VACUUM LINE AND REPLACE THE RUBBER NIPPLE COVER.
10. AFTER THE 5 MINUTES START YOUR CAR AND MAKE SURE YOU ARE IN A WELL VENTILATED AREA. DEPENDING ON THE AMOUNT OF DEPOSITS REMOVED, THE MORE SMOKE YOU WILL GET.
11. AFTER YOUR CAR IS DONE SMOKING, YOU ARE DONE.
