one thing I find very annoying with our headlights is that the cut off shield inside the projector is the same left & right, wouldn't be an issue if they were symmetrical side to side, but there not, they both step up midway from left to right, so the projection appears as a step up to the right, then another step up to the right. this is not right, it should step up to the outside of each respective light, so the left should step down to the right & the right should step down to the left, or vice versa even would be better than just both sides the same... don't make sense... it's like there 2 right sides or 2 left sides, but not like I would ideally want a left & a right to be.
right now there like this: )) or >> where they should be either : )( or <> or even () or ><... strange that they did the shields like this... I wonder if other manufactures do the same... very odd...
I always considered playing with tsx projectors, but up until now original tsx projectors that I have seen have always been at least $120 a pair, shit, I could buy a complete set of fx headlights for that...on top of that my lights would need 2 pairs. as cool as this mod is, it really doesn't have much impact with normal day to day use, not very noticeable to most really, never really thought the benefit was worth the cost. now, these reproductions though, if really as good as the real things might be a bit more worth it since there like 1/2 the price
I really think that the focus issue is more a result of the distance of the projector from the shield, not the bulb... that edge of the shield is probably more of what is being projected & focused really I think... a spacer may make good results, gonna play with focusing first with the OE projectors & see
