Anyone Know if any of the claims made here are true and if this would be a good Mod to do?
[FONT=Trebuchet MS, Arial]03-08 INFINITI FX35 PERFORMANCE POWER/SPEED CHIP +MPG[/FONT][FONT=Trebuchet MS, Arial]
Addicted to your car?
We have your fix with the Chronic Power Chip!
Add 25-50 Horsepower and 35+ ft/lbs of Torque!We have your fix with the Chronic Power Chip!
Add up to 5 MPG to your Fuel Economy! And Reduce Emissions!
Works on all Fuel Injected models (except turbo) of this vehicle!
100% Legal in USA, Will Not Void You Warranty!
Safe, will not hurt your vehicle or electronics!
Smoother Accelleration! Increased Top Speed!
Easy install, can be done in less than 5 minutes with NO TOOLS!
The Chronic Power Chip is designed to maximize the power potential from your vehicles current setup. The chip will work with a completely stock vehicle or with modified vehicles. Its easy to install, fully reversible, and requires no cutting or modification of your vehicle. Each one of our Power Chips Come with detailed installation instructions.
Comes with 30 Day No Questions Asked Money Back Guarantee! Also comes with a Lifetime Replacement warranty. If it ever fails, we will replace it free!
Have you ever wondered why your car seems so much faster when it is cold outside? It is because your computer senses intake temperature through a special sensor in the intake which controls fuel mapping and Ignition timing. When it is hot outside, your fuel and timing change and your vehicle becomes sluggish.
The Chronic Power Chip, Once Installed, will tune your computers fuel and timing maps to the same mapping used when it is cold outside. This will result in an IMMEDIATE and Noticeable change in power and acceleration. Also, since your computer is essentially leaning out the fuel mixture (injecting less fuel), you should notice an increase in fuel economy almost immediately!
In Fact, This item gives so much power, it is often referred to as the Drag Racers Mod!
No more worrying about your vehicle loosing power as it sits in crawling or stopped traffic. When your vehicle sits idling, it creates its own heat and can increase your Intake Air Temperature, thus reducing your vehicles performance. Not so with the Chronic Power Chip. Now you can have that extra power to get to that opening in traffic, or pull away from that annoying tailgater.
This item does the same thing that more expensive Power Chips do. They come in fancier packaging, but function just the same. If you don't believe us, test ours head to head with the competition, and if we don't equal or beat their results, we will give you your money back. So if you just bought that expensive chip, try ours out, you still have time to send the other back!
[/FONT]
