Well the akebono are sports brakes, they are not really considered BBK from what I have read
Didn't the 09 FX50 have the regular and the FX50S versions? I thought the AKEBONO's were only on the S version and the smaller brakes were on the regular FX50...They're not a BBK formally, they're just the sport brakes for the G/Z and the only brake for the FX50.
Yes, the front wears out twice as fast.I'm trying to source the bbk upgrade as well. Can someone clarify the stock 20 inch wheels fit without spacers with the bbk? someone on another post said they have 25mm spacers but didnt say if it fits without.
also anyone just do the fronts?
tia
I got my calipers from circle Infiniti on eBay. They were much cheaper then they are now and all you really needed to remove was the break dust shield since you are getting bigger rotors. I never ended up swapping them and just had the mechanics cut them in order for the calipers to fit.Okay, I'm ready to order:
- Stoptech drilled or blank rotors (FX50S sizes, from TireRack)
- Stoptech street pads (or similar, recs?)
- 4x banjo bolts (Techna-Fit from ConceptZ)
- 1L OEM (or equivalent) fluid
- ... calipers!
Where is the best place to source the calipers these days? I'd like the silver/Infiniti colorway.
Searching around, people talk about how cheap they're getting them for, but I am not finding any cheap listings/sources. New would be ideal but lightly used would also be okay.
And no need for special brackets or anything more to my QX70S 3.7? G37 or M37 or any other model with these Akebono calipers will bolt up perfectly, I just need to trim the dust shields? Thanks!
