WietseFX35
- Netherlands
- 2009 FX50S AWD
He guys,
Recently traded in my 03 FX35 for a 09 FX50S with 19K miles...what a upgrade!
Just wondering a few things here.
I've been reading about wheel spacers for my OEM 21" Enkei wheels and want to go for 15mm up front and 25mm at the rear.
I am concerned about the OEM wheel studs will stick out the spacers, does the OEM wheel have these pockets in the back to accomodate any stud length sticking out?
I want to use the H&R spacers with DRM system, which are the ones which you bolt on the original wheel studs and provide another set of stud to bolt the wheel on.
Another thing are the TPMS sensor, i have a set of winter wheels which don't have the sensors, will the OEM wheel sensors still work after they have not been on the car for a few months?
Bacause i don't really see the point of reprogramming the sensor every time when i change from the winter to summer wheels and vice versa.
So if the can be lying in the garage for around 3 months and still work after reinstalling them that would be the easiest way to go. (assuming the batteries are still good)
Any info is welcome!
