illestFX35
- Los Angeles/Glendale
- 2010 FX35 RWD
Probably will need to wet sand a little bit, then polish. But definitely wait for the paint to cure. Since the weather is still cold, it will take a little longer. This is pretty normal, if any body shop painted the lights, they sand and polish. It's paint, it's not going to be perfect without finish work.
I guess there is a chance but I've never had that problem. If you are really worried about it you could do another coat?
When you wet sand, you'll see the surface texture change and the goal is to get a consistent finish on the entire surface - but it will be much more matte after 2000 grit. Then when you polish they will shine right up. No harm in starting with polish - if it's enough then there is no reason to wet sand so I say start with a compound and see what it looks like.
