Verde parallax v39 22x10.5 offset 45 -tire size help!!!!
Michael135319
new york
Michael
I just bought verde parallax v39 wheels for my 2009 fx35 awd. They are 22inch by 10.5 offset 45. The car is lowered on h&r springs. I am in a bind on ordering tires. They are telling me that the right size tire is 265/40/22 and I am reading forums that say 285/35/22 is the right size. can some one help me out. I am ordering tires today and i would like to fit 285/35/22 on there.
265 is too narrow unless you want a 'stretched' tire look. The 285/35 will work better, go for it....
---------- Post added at 09:34 AM ---------- Previous post was at 09:32 AM ----------
By the way that is a lot of wheel and tire, if you have not already upgraded your brakes you might want to consider doing so.
I barely drive this car( regarding brakes) . Also can I use my spacers in the back which are about 1.25inch (30mm i uses these on my factory 20inch )or will i rub and have alot of poke.
265/40 and 285/35 are both correct and will get you within stock specs for rolling diameter. But for 10.5" wheels, you'd want 285/35. 265 would be if you were running 9" wheels. 265 on a 10.5" will be stretched (I run 275 on 10.5" and there is already slight stretch).
Running a 30mm spacer is probably not recommended. +15 will poke out unless you're slammed, it will tuck if you're low enough. I'm at +0 in rear on my first gen and the rim barely pokes out, but that required camber and lots of fender work.
Don't buy spacers before test fitting your wheels. Fit your wheels, take some measurements and then buy spacers if needed. It's your car, the look is yours, not anyone elses. Everyone has a different opinion on fitment and so on. And people have very different definitions of flush. I think my car is flush, some people think the wheels are way too aggressive. What others consider flush, I consider to be very tucked.
For spacers, really anything that is hub centric will be fine. I get mine through eBay since I swap a lot of sets out. So far, I haven't had any issues with vibration. If you need 15mm or larger spacers, I'd highly recommend bolt on style. Much easier to install than the kind where you have to press in new studs, plus you don't run the risk of damaging your hub bearings when pounding out the old studs.
I put on the wheels today and car looks very nice. I need a 10mm spacer in back to make it perfect. I do not know how to post pictures. I can't find the attachment.
I have attached the picture on my profile album, I guess you can see it there. What do you guys think of the Kazer lip kit or do you think i should stick to OEM aero kit?
PICture with 22inch verde parallax wheels with h&R
attachment.php
attachment.php
attachment.php
---------- Post added at 04:33 AM ---------- Previous post was at 04:32 AM ----------
Next is Factory aero kit and paint calipers. Anyone has any suggestions what color I should go with Red,Silver or Gold? Any ideas or pics?
