transmission fluid help
FXchris305
miami
2005 Honda S2000
hey guys i got a question about changing the transmission fluid. if i drain the transmission fluid through the radiator hose way , when the fluid stops draining out does that mean i drained all the fluid in the transmission or just the fluid in the torque converter .?? :confused:
It probably means you just drained the fluid in the cooler and the lines leading to the cooler.
Here are the instructions from the service manual.
A/T FLUID​
PFP:KLE40​
Changing A/T Fluid​
NCS001AT​
1. Warm up ATF.
2. Stop engine.
3. Loosen the level gauge bolt.
4. Drain ATF from drain plug and refill with new ATF. Always refill
same volume with drained ATF.​
To replace the ATF, pour in new ATF at the A/T fluid charging
pipe with the engine idling, at the same time drain the old ATF
from the radiator cooler hose return side.
When the color of the ATF coming out is almost same as the
color of the new ATF, the replacement is complete. The
amount of new ATF to use should be 30 to 50% of the stipulated
amount.
CAUTION:​
Use only Genuine NISSAN Matic J ATF. Do not mix with other ATF.​
Using ATF other than Genuine NISSAN Matic J ATF will cause deterioration in driveability and A/
T durability, and may damage the A/T, which is not covered by the warranty.
When filling ATF, take care not to scatter heat generating parts such as exhaust.​
Do not reuse drain plug gasket.​
5. Run engine at idle speed for 5 minutes.
6. Check A/T fluid level and condition. Refer to​
AT-13, "Checking A/T Fluid" . If ATF is still dirty, repeat step 2.
through 5.
7. Install the removed A/T fluid level gauge into A/T fluid charging pipe.
8. Tighten the level gauge bolt.
ATF: Genuine NISSAN Matic J ATF
Fluid capacity: 10.3 (10-7/8 US qt, 9-1/8 lmp qt)
Drain plug:
: 34 N·m (3.5 kg-m, 25 ft-lb)
Level gauge bolt:​
: 5.1 N·m (0.52 kg-m, 45 in-lb)
Checking A/T Fluid​
NCS001AU​
1. Warm up engine.
2. Check for A/T fluid leakage.
4. Before driving, A/T fluid level can be checked at A/T fluid temperatures
of 30 to 50​
°C (86 to 122°F) using “COLD” range on A/
T fluid level gauge as follows.
a. Park vehicle on level surface and set parking brake.
b. Start engine and move selector lever through each gear position.
Leave selector lever in P position.
c. Check A/T fluid level with engine idling.
d. Remove A/T fluid level gauge and wipe clean with lint-free
paper.
CAUTION:​
When wiping away the A/T fluid level gauge, always use
lint-free paper, not a cloth one.​
e. Re-insert A/T fluid level gauge into A/T fluid charging pipe as far as it will go.​
CAUTION:​
To check A/T fluid level, insert the A/T fluid level gauge until the cap contacts the end of the A/T
fluid charging pipe, with the A/T fluid level gauge reversed from the normal attachment conditions.​
f. Remove A/T fluid level gauge and note reading. If reading is at low side of range, add ATF to the A/T fluid
charging pipe.​
CAUTION:​
Do not overfill.​
5. Drive vehicle for approximately 5 minutes in urban areas.
6. Make the A/T fluid temperature approximately 65​
°C (149°F).​
NOTE:
A/T fluid level will be greatly affected by temperature as shown in figure. Therefore, be certain to
perform operation while checking data with CONSULT-II.​
a. Connect CONSULT-II to data link connector.
b. Select “MAIN SIGNALS” in “DATA MONITOR” mode for “A/T” with CONSULT-II.
c. Read out the value of “ATF TEMP 1”.
7. Recheck A/T fluid level at A/T fluid temperatures of approximately 65​
°C (149°F) using “HOT” range on A/
T fluid level gauge.
SCIA7120E
SLIA0016E​
AT-14
A/T FLUID​
Revision: 2006 December 2006 FX35/FX45​
CAUTION:​
When wiping away the A/T fluid level gauge, always use lint-free paper, not a cloth one.​
until the cap contacts the end of the A/T fluid charging
attachment conditions as shown.
8. Check A/T fluid condition.​
If ATF is very dark or smells burned, check operation of A/T.
Flush cooling system after repair of A/T.
If ATF contains frictional material (clutches, bands, etc.),
replace radiator and flush cooler line using cleaning solvent
and compressed air after repair of A/T. Refer to
CO-14,
"RADIATOR"
(for VQ35DE) or CO-41, "RADIATOR" (for
VK45DE) and
AT-15, "A/T Fluid Cooler Cleaning" .
9. Install the removed A/T fluid level gauge in the A/T fluid charging
pipe.
10. Tighten level gauge bolt.
Level gauge bolt:​
I recently got a radiator,engine,trans flush I bough everything from nissan not the oil( RP) they told me they replaced Matic j with Matic S, so that's what I used for the trans flush..
