guy8689
I did not find a write-up on how to remove and clean the throttle bodies on the 2nd gens. I will be cleaning mine most likely this weekend, should I take the extra time and take pictures or is it not really worth it?
I followed this video http://youtu.be/L6KoD5V2hVk to do it on my FX09. 60 min max DIY.
It fixed the jumping rev at low RPMs
Jordan, how many km do you have on your FX? I ask because my dealer replaced my TBs instead of cleaning them. They're like "no it cant be cleaned or repaired. It'll cost you $2k for part and labour to replace them".. Went through a battle but finally got it done under warranty. And at the time of replacement my car had about 80k km on it; but the symptoms started at around 55k. not sure how often it should be done.
Nima, you have 80,000 Kim's, that is what I have, no problems so far.
I believe Jordan has around 58,000 miles (100,000 Kim's)
when i clean my throttle bodies can i put my car in the "on" position with the engine NOT running of course and stepping on the throttle and will the valves open? ive done this on other cars with electronic throttle bodies and it worked out fine.
