Thanks for all the useful information
halschmidt
Okmulgee, OK
G37
I am new to this forum and been having trouble posting and getting certified. I am retired and been using computers all my life. I have 2004 FX45 that I just bought and have found information that has helped my change filters, plugs and antifreeze. I am still trying to solve a P0507 error code problem and having trouble posting a new thread.:tup:
You should really just take it to infiniti until you add more variables to the problem. I have been back and forth to the dealer and I just let them deal with it, plus I dont mind having a new loaner:tup:
The problem was the AC was on. View attachment 243210 I turned it off and it worked on my first try. View attachment 243212 I missed the part about the "load switch"
Before performing “Idle Air Volume Learning”, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
Battery voltage: More than 12.9V (At idle)
Engine coolant temperature: 70 - 100°C (158 - 212°F)
PNP switch: ON
Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, set lighting switch to the 1st position to light
only small lamps.
Steering wheel: Neutral (Straight-ahead position)
Vehicle speed: Stopped
Transmission: Warmed-up
My engine now idles around 500 rpm and I saved a tripe to the dealer. My thank to everyone who posted all the info.
