edmarin
So this is how i installed my strut bar for my fx. Its pretty simple just take your time and do this at your own risk i aint responsible for anything that may go wrong
If you are hand it should go smoothly
First off buy a strut bar :tongue (2):
i got mine from gtspec
next pop ur hood n examine the location of where the anchor points go to
you can start either side BUT THIS IS IMPORTANT NO NEED TO LIFT YOUR FX TO DO THIS WITH IT THE FX ON FLAT GROUND IS OK AGAIN NO LIFTING NEEDED....
I started the right side
Unbolt the 3 bolt holding the shock in place once all 3 unbolted remove the struct bracket
now put the strut bar bracket on the screws
after checking fitment bolt it down and torque it with specs in manuel
you do the same to the other side as well bolt it down and torque it make sure not to tight or ull pull the strut and the is a big UH OH
once the brackets are in place put the bar and crew in the brackets i tighten it by hand just a little more then snug
afterwards enjoy looking at you engine bay with the bar :top::top:
happy modding
happy modding
