Some photos of my ride
He say camber was -2.45, that's the angle. That's pretty decent for his drop to me. Most performance oriented cars are in that ballpark. Most stock cars are in the -1.5 ball park.
You should be more focused on zero-ing out toe if u want tires to last. I had them adjust my camber to -2.5 to avoid rubbing. After my fender roll, I could get it redone to maybe -1.75.
I know when I had my fx dropped my camber was close to that or a bit better, but I could not dial in the zero toe.
Here is me at -2.8 or so. You can see how the outer edge is not touching the ground.
I wasn't slammed either. I just didn't have a camber kit and i was already rubbing if i had someone sit in the back.
No recent picture. This is what i'm running now -2.8 in the front and -1.5 in the rear. I like it like that, tire wear isn't extreme on my fronts. But you can use these to gauge how \\ my tire is rather then ||. Most beamers are running some decent camber all around. Hence why they need tires rather quickly. My friend's M3 goes thru tires about every 10-15k.
there is anither dropped Fx 50S in Russia ( he is also on coilovers)
last pics set of wallpaper :):)
---------- Post Merged at 08:38 PM ---------- Previous Post was at 08:38 PM ----------
I've installed new grill:
