santiagodraco
- Austin, TX
- 2010 FX 50s
That would be great if we had a camber kit available for the 2nd Gen. SPL told me they will not produce one until they get a great enough demand for it.I'm not too worried atm.
I'm planning to order a lower control arm (the specific piece that would control camber) and will be providing it to SPL in the hopes we'll get a custom arm made.
The drop looks real good now u just need some spacers
I'm pretty sure sport mode changes the rate of shock compression in turns, not so much when you hit a bump. So if you turn it on you should notice a bit less roll. My assumption, not fact. Also a slight increase in firmness.
With the spring install you will already see less roll because of the lowered center of gravity and the spring change itself. Plus the FX, at least the 50 for sure, has pretty beefy sway bars, so we are already pretty stable in the turns. All that together and it sticks pretty level in tight turns.
