Renhalt
- Lexington, KY
- 2008 fx35
Well guys, just like a lot of you I was not happy with the mediocre stock sub. So I looked at the different options, I did not want to loose my space with a speaker box, and I did not want to loose my spare. I also did not want to pay the inflated price for the magic box. SO, i made my own setup and I figured if bose used the spare tire I could as well. After a lot of research i zeroed in on planet audio as i knew their products were good and last but not least inexpensive. The entire set up ended up costing me about $250.00 total including the amp, sub, capacitor, fiberglass, resin etc. I did a 10 inch sub that is rated at 800 watts with a 1000 watt amp and bridged it. I wish I had gone with the 12 as after doing it I realized I had enough room for the 12 and i still may do it. All in all it was pretty straight forward and I wont bore you with every detail. I will however say that I had problems with the sub flattening out after 1/2 volume, I called planet audio and the tech was very familiar with our cars and said the problem was the signal i was getting from tapping into the stock sub harness as described on another post. the bose system is designed to reduce the amount of signal to the sub as to not overload it. Therefore when I was asking for more it was giving me less, If that makes since. Anyway i took his advise and tapped into the right rear door speaker which gives a full range signal and wow is all I can say. My system sounds the way it should and hits hard as hell! Anyway, check out the pics and if you have any questions just ask, Oh yeah, I bought everything on amazon and the sub, amp and capacitor and amp wire install kit was $168.00 shipped. Also while I was at it, I took it to a boat shop and had a mold casted if anyone is interested in maybe buying one.
I used a spray paint lid to make room for the knob that holds the spare tire in place. I obviously had to cut it down and rethread it to work.
///5772[/ATTACH]
All tapped up and ready for glass
///5773[/ATTACH]
First layer of glass
///5774[/ATTACH]
///5775[/ATTACH]
///5776[/ATTACH]
Finished product
///5778[/ATTACH]
///5777[/ATTACH]
///5779[/ATTACH]
I think it came out great and the only room I lost was where I mounted the amp not bad for the difference in sound!
///5772[/ATTACH]
///5773[/ATTACH]
///5774[/ATTACH]
///5775[/ATTACH]
///5776[/ATTACH]
Finished product
///5778[/ATTACH]
///5777[/ATTACH]
///5779[/ATTACH]
