On my mind (turbo's supercharger for sale)
yeah dude, have you ever really checked out these HR's? there friggin sweet man, guys are running over 500hp bone stock with them... how much more could an fx handle? to me, the HR motor is as good as a built DE for our application really, but still at a fraction of the cost... all the motor the fx could ever want or use without ripping the fx drive train apart. we certainly couldn't harness 800hp or more without extreme measures, so how much is enough... to me, the HR is enough:biggrin:
I've always been a huge fan of engine swapping, usually the best bang for the buck. I've considered a few different swap scenarios in the past with the fx, but none were as good of a "fit" as the HR motor... check this thing out:
first, the DE bottom end
now, check out the bottom end of the HR
now check out the rods, left is the HR, right is the DE
hard to say exactly, but I'm shooting to make close to 500hp for well under 10k. depends on what route I go for FI really. of course, this is not including labor...
I half considered a rwd conversion before as part of an ls6 tt swap where that would have been much more practical for that, but I've grown to really like the fx awd system... want to do a swap without butchering the hell out of the fx. don't want a race car, just want the fx for just what it is & just the way it is, but need more power :tongue:
I'm going to use a g35x drivetrain for this swap... still a lot of details to work out though, but minor compared to the alternatives I've considered...
Eh... the rods still look weak sauce compared to Eagle H-Beam or Pauter. The angle of the picture is a little deceiving too.
Who's to say about the pistons as well... but keep in mind, the VQ35DE motor has been holding 450rwhp on stock block 350Z's using the JWT TT kit, and very reliably at 400rwhp.
Have you put any thought into valve springs, rods and/or pistons?
I have put thought into lowering the compression a bit but haven't researched all of my options there. rods don't look like there going to handle 800 & better like eagles or pauter, but compared to the DE stock rods they do look much beefier to me...
I guess to me I'd rather go HR over DE so instead of being at the jagged edge with the DE, I would be in very comfortable range with the HR. also, keep in mind that part of the equation is I'd be replacing an over 60k mile motor for a 5k mile motor, which is worth most of the price too.. just makes sense as a viable swap to me
the HR motor has a lot over the DE, clipped from nissan performance magazine:
Engine
And now the part you have all been waiting for, an engineers look inside the much anticipated VQ35HR, the next generation of VQ engines from Nissan. According to Nissans PR hacks the HR moniker stands for "High Rev" and "High Response". Although this sounds somewhat hokey, it is a lot less dumb sounding than the current top of the line "Rev Up" spec engine. Although some of these specs and rumors have been floating around on various web sites for awhile now, we will add our own analysis to things and explain why certain things are being done and how they work.
Here is what is left of the motor. The dual intake plastic manifold is missing.
There are some differences seen in the specs of the new motor vs the old right off the bat. Nissan claims an increase of 10% in fuel economy and emissions reduction. The compression has been increased from 10.3 to 10.6:1. The power has gone up to 315 hp ps or around 306 hp SAE. The engines redline has been increased to 7500 rpm.
It seems like Nissan is up to something here as this engine is much more beefy inside than previously. In our opinion Nissan is getting ready to subject this engine to turbo boost for the long awaited R35 Skyline GT-R. Here is why we think this.
The stout bed plate block holds' the crank in this stout cage. This should take over 1000 hp no sweat.
The block is much stronger. It uses a bed plate type lower end, much like that what is seen in engines designed specifically for racing like the Cosworth powerplant used in Champ Car racing and others used in F1. A bed plate block is one where the block is split at the crankshaft into an upper and lower portion. The crank is solidly supported by a huge girdle of aluminum solidly bolted to the block at many points instead of individual main caps that most motors have. There is little opportunity for block flex and bearing eating, crank breaking distortion here. This beefy lower end was first seen on the heavy duty VQ40DE motors used in the Pathfinder and Frontier trucks. The crank is beefed up as well featuring the larger rod and main bearing journal diameters of the heavy duty VQ40DE truck engine.. Can you see the future potential for GT-R turbo boost here?
Look at the beef behind the crank. Its way more stout than the VG30 or the VQ35DE. Plenty of journal overlap and bearing area should allow this pup to handle 1000 hp of boost.
The block itself has a taller deck height than the older VQ35DE. This was done to accommodate longer connecting rods. Longer connecting rods improve volumetric efficiency at high rpm by giving more dwell time at TDC. This gives the cylinders more time to fill on the intake stroke, improving high RPM power.
This looks like an old school VG or SR rod. Nissan beef is back. The rod has lots of material and is strong. It should probably be able to take 600 hp stock. See the thick parting line down the middle of the beam? This indicates that its forged or PM, not cast like NICO says. Longer rods also improve mechanical and combustion efficiency. This is because the combustion event has a longer dwell time to initially push harder on the piston as it travels downward down the piston bore and the connecting rod has less angularity so it will not cause the piston to cock in the bore and dig as hard into the cylinder walls. This puts less stress on the piston and connecting rod as well as reduces friction.
The pistons have some interesting features, mainly an asymmetric shape with a larger skirt area on the thrust side for good support and a cut down skirt on the non thrust side for less friction and less weight. The rods themselves have been beefed up with more meat around the big end and a wider beam. VQ rods have been known to be problematic on higher revving and boosted motors
The pistons most innovative feature is the wide skirt on the thrust side to support the thrust loads better and the narrow skirt on the opposite side for less weight and friction. What a good idea! Soon the aftermarket will copy this. and this appears to be a good thing, returning to Nissans prior heritage of having near bulletproof rods. The NICO website has reported the rods to be a high pressure casting be we think that is not correct, in photos of the rods the thick parting line of a forging die or a PM (powdered metal forging) die are clearly seen. A cast rod would be inferior to a forged or PM part so we think that NICO is mistaken. The piston ring lands have been hard anodized for better wear and the skirts feature a low friction polymer coating. The dome configuration appears to be little changed form previous VQ variants.
The cylinder heads seem to be an evolution of the current VQ head rather than a revolution like the rest of the engine. The heads have a variable cam timing VTC device on both the intake and exhaust cams with the intake being infinitely variable hydraulic and the exhaust being a two step electromagnetic clutch. This configuration appears to be nearly identical to that found in the current Rev Up spec engine. VTC can control the cams advance, retard and lobe centers but not the actual lift and duration like Honda's VTEC system can. The intake port has a straighter more line of sight direction presumably for better tumble and mixture consistency in the cylinders as well as better flow.
A JDM Nissan diagram showing how the longer rod and the asymmetrical piston skirts work.
Unlike the VQ35DE, which had an open quenchless combustion chamber, the VQ35HR has a pentroof chamber with quench pads on either side of the intake and exhaust valves, much like the older VQ30DE had. This is presumably where the increase in compression ratio came from and should also result in better combustion and less detonation due to higher mixture turbulence and more homogeneousness of the fuel air mixture as the piston hits TDC on the compression stroke. There are rumors that the HR has larger valves but we cannot confirm this.
A big improvement over the VQ35DE, the VQ35HR has a combustion chamber that has two quench pads per cylinder for improved combustion and detonation resistance.
The HR has different camshafts and valvesprings to support the higher revs
The tops of the cam followers are coated with a Diamond Like Coating for maximum reduction in friction. and the cam followers use a DLC coating which Nissan is quite proud of. Nissan claims that this is the first use of DLC in a production engine. DLC is short for Diamond like coating. DLC coatings have been used for some time in NASCAR and drag racing for cam followers and piston pins to my knowledge and probably other high end motorsports applications for sure. DLC is a thin layer of diamond like carbon which is the hardest and slipperiest stuff known. Nissan credits much of the HR's friction reduction to this coating. The NICO web site has reported that DLC is used in the pistons, this is simply not true. The piston coating is an organic dry lube much like Teflon.
Looking at the front of the engine is interesting. The front cover no longer has an access port for the water pump. This means that changing a water pump is going to take some work. I hope Nissan improved the water pump while they were in there! The rear of the block has the same bellhousing bolt pattern as the VK45 and 56 as well as the VQ40DE, some interesting info for all of you swapaholics out there.
The intake port has a new line of sight layout for better flow and tumble into the cylinder on the intake stroke for better mixing of the fuel air mixture. (photo courtesy of JWT)
The peripherals of the engine have changes for the better as well. The exhaust manifolds are now close to equal length tubular headers! There is probably not much room for improvement by the aftermarket here. The intake manifold is now plastic with a larger plenum and shorter, bigger diameter runners. The plastic is very smooth in the ports which should result in excellent flow. The plastic does not conduct heat well which should mean a cooler intake charge. The most interesting thing is that the plenum now sports dual throttle bodies, dual intake tubes, dual MAF's and dual ram cold air airboxes. Again the aftermarket is going to be hard pressed to find improvement here.
The exhaust manifold is a close to equal length header. It looks very close to the DC header for the 350Z.
The exhaust is a true dual system and sports an X-pipe in the middle. The most powerful aftermarket 350Z exhausts by Stillen and B&B have found that an X pipe really helps improve low end torque with no sacrifices anywhere else. Nissan claims that the new engine sounds good due to the intake and exhaust systems having the same length but we feel that this is due to the X-pipe. The exhaust also features close coupled cats with low thermal mass for quick lite off and a big reduction in emissions. This usually means that the cat monolith is ceramic which has been the cause for a lot of grief with the QR25DE 4 cylinder. The ceramic is brittle and prone to fracture. The engine's VTC sometimes causes a vacuum in the exhaust manifold because it uses cam timing induced exhaust reversion in lieu of an EGR valve. If the cat fails, this can result in the abrasive ceramic getting sucked into the engine. Better hope Nissan has solved some of these problems.
The all plastic intake manifolds most noticeable feature is dual throttle bodies and intake tubes.
The injectors are a multi hole, 50 micron droplet high atomization design for good burn. (photo courtesy of JWT) The engine also features improved faster warming wide band O2 sensors for better sensing of the A/F ratio. We figure that these are a refinement of the current Bosch technology with a hotter heater, like a Horiba reference sensor. The injectors are multi hole 50 micron spray type for super good atomization. A fine wire iridium center electrode on the plugs helps them get free of fouling from a cold start faster. The cats, O2 sensors, injectors, iridium plugs and dual VTC help the HR get the nearly impossible for a high performance engine, SULEV rating.
The HR engine will be the workhorse engine for the Z in the near future but even better stuff may be coming later. It is a strong, nearly confirmed rumor that the engine used in the upcoming super secret Skyline GT-R will use a twin turbo 3.7 liter version of the HR motor topped with some secret cylinder heads developed by none other than Cosworth. The new Cosworth heads will also feature Nissans VVL technology where lift, duration, lobe centers and advance can be controlled by the engines ECU, much like Honda's I-VTEC system. The turbos will be smog friendly using Cosworth technology that bypasses the turbos during cold start.
From this angle you can see that the motor did have dual intakes at one time.
The rumor mill also states that a 3.7 liter version of HR will be coming for an enthusiast package Z and a very limited production high hp version of the 3.7 with high compression and Cosworth heads, naturally aspirated is on line for the track model. Interchangeability with the VQ40 means that other interesting combos can be made by the tuners. We predict that it will be fairly easy to get up to 4.5 liters from this platform.
The VQ35DE is dead, long live the VQ35HR.
well maybe not. I'm exploring the possibility of using the stock ecu & the utec believe it or not.
the hr & the de should use all the same sensors I think. forgetting about the intake for a minute, the only real difference to the ecu with the hr is that the hr also has variable exhaust valve timing, just like the rev up did. this variable timing is much more simple than the intake though, the intake is infinitely variable, but the same as the de really, so that should be compatable. the exhaust is a very simple solinoid control, on-off. the stock computer will niether be able to control this, nor even see this really, but this control could probably be regulated to one of the aux solinoid controls from the utec or another simple control could be added, I'm guessing so far that the switching of this exhaust valve solinoid is rpm based, but maybe load based as well, both of which I think the utec can handle, if not can be handled independently maybe. the utec can raise the rev limit too.
my thinking is that if the stock ecu was used with the hr motor it would work, but now, the intake is going to be the biggest difference & the challenge.
easiest solution is to run one throttle body. I'm thinking that an hr dropped under our harness, with a single throttle body & the utec will be able to run well.
then, there is the possibility of using a module that speedforceracing uses for it's dual throttle body setup that they developed for the de, it allows dual tb's to be controlled by the single tb control of the de computer by slaving one to the other for there custom dual intake. this could probably be used with the stock ecu to run with the hr dual manifold on the stock de computer too, more on that here: http://speedforceracing.com/productsinfinity_g35imani.php
the utec can run speed density, so the maf shouldn't be an issue if I did do dual tb's...
I still need to get under a g35x & check out the drivetrain, but I'm thinking it should bolt in to the fx really as a whole & be very similar... I think. the mounts & everything should be the same, the hr motor uses nissans larger tranny bell housing pattern though, same as the vk & the 4.0 pathfinders really, but the g35x tranny should solve that. if I just had the hr motor then I'd have to swap to a fx45 bell housing to mate the hr to the stock fx35 tranny...
honestly, I'm thinking the hr swap shouldn't be teribly difficult keeping the stock ecu. if I had to do a whole ecu swap, then compatabilities to the other modules on the fx would be a major hurdle, like bcm & tcm integration etc, that could get really complicated really quickly... I originally looked at the g37, but the no tb, variable valve lift setup would really require the 37 ecu for sure... if I was to have to do the complete ecu swap & deal with all of that, at that point a mildly built de would start to make way more sense. the hr is only very cost effective if the oe engine management can be used, which is something that I'm still researching & hoping can be pulled off
John question! So the S/C kit you are selling will increase the FX whp to 300 right? How many WHP does the stock FX genarate?
Thank you
Don't rely on this shop for anything. Research how many times they have modified their intake manifold and never produced results. There's a dyno 1/2 mile from their shop.
Their turbo kits suck too. :eek: Ebay looking headers and other things that look like crap minus shininess.
cool, good to know, thanks viet. really they want $499 for there module & harness anyway which is a lot, I was thinking I might be able to build an interface myself for way less, just need to slave the 2nd tb to the first, figured they showed that part of it can be done at least if nothing else.
rubare, depends what other mods you have. with bone stock exhaust it might even be right at or even a little under 300 with a conservative tune, also depending on the dyno. putting this in perspective, if you ran against a fx45 now the fx45 would start to pull away from you, not anialate you but def show that it's stronger than you. after this charger is installed on a stock fx35, you will be able to pull away from a FX45, not totally anialate him either, but you should be stronger. a fx50 will probably still pull on you a little with just this charger & all else stock on your fx I think
now unlike the stillen intake mounted blower, a centrifugal charger like this should really benifit & wake up from a free flowing exhaust. stillen 2.5" dual exhaust was my choice, I also added headers in prep for this too. at that she should be a bit over 300, exact numbers are not so meaningful because it can vary dyno to dyno too but for example maybe 315 give or take. past this you could go down one size in the pulley pretty safely with the upgrades I did to the compressor for a bit more boost & add an alcohol injection to run a bit more timing, at that point your up in & probably past the fx50 range... I would say conservatively that 335-340, maybe 350whp is going to be about the max this unit will get you too without sacrificing reliabilty, again, it's not for someone that wants to go all out, but it's nice to escalate your power a bit & get respectably quick at least without being all kinds of loud & spending all kinds of $$$. I'm being a little conservative in my #'s & a lot depends on tune, more power can be made than this even, but this is pretty realistic in what to expect I think
I bought it cause I figured that would be good enough, but now I'm itching to maybe step it up a notch or 2 & go for about 100 more whp than this which is why I'm looking to do the HR motor, at least 430 & more to the wheels sounds good to me right about now:tongue:....
my dyno bone stock was at about 215whp, before I did anything, haven't dyno'd since
thank you john very detailed answer as usual.. I know your S/C won't be staying for sale for long cause must likely someone will jump on asap. My fanancials are a bit low if not I would kindly take it from you sir.!! I woud so love to have that kind of power on my fx. But ultimately 500+ whp would be my goal In a very distant future..
