Koso Kustomz
- Idaho
I'm going to try something new here, rather than having 5 different threads of different products, I talked to the Staff, and we wanted to try this out. Everything that is not going to be a Group Buy will be posted in this thread. I think it will be a good way to keep everything in one place for you guys.
KRAUTO HID CONVERSION KITS:
http://www.kosokustomz.com/#!our-store/vstc3=hid-kits-&-lights/productsstackergalleryv29=0
We just started caring this product, I have been running this kit in one of my cars for about 3 weeks, and I'm very happy with it.
PRICE:
$49.99 - FREE SHIPPING TO US AND CANADA
Complete Slim Line HID Conversion Kit, Direct plug and play for your headlights and fog-lights, no cutting or splicing of your factory wiring
Digital Slim 12v 35w Ballasts
Waterproof/Weatherproof/Shockproof
Rubber Sealed Bulb Connectors
INCLUDED:
2X Slim 35w Digital Ballast
2x HID Bulbs
2x Ballasts Mounting Hardware
3 Year no questions asked warranty
Bulb Sizes:
H1,H3,H7, H8, H9,H11,9005,9006,D2S
BULB COLOR CHART: * 12000K is not available in this kit
3000K Color:
__________________________________________________ ___________________________________
INVIDA GEMINI CAT-BACK EXHAUST SYSTEM ROLLED TIPS:
http://www.kosokustomz.com/#!our-store/vstc3=engine/productsstackergalleryv27=15
[video=youtube;n1iVEp0ZAzY]http://www.youtube.com/watch?v=n1iVEp0ZAzY[/video][video=youtube;O0jhzZqvMpk]http://www.youtube.com/watch?v=O0jhzZqvMpk[/video]
FITMENT:
03-08 INFINTI FX34 AND FX45
(Except 06-08 FX45 HAD LONGER CATALYTIC CONVERTER NEED TO DO MODIFY)
Item No.:HS03IFXGIS
Piping Dia.:60mm
Tip Dia.:101mm
PRICE:
MSRP: $1300.00
Contact us for best pricing.
UNICHIP PIGGY BACK PROGRAMMER - INCLUDES Flux Power Display:
FX35 PROGRAMMER:
http://www.kosokustomz.com/#!our-store/vstc3=engine/productsstackergalleryv27=23
FX45 PROGRAMMER:
http://www.kosokustomz.com/#!our-store/vstc3=engine/productsstackergalleryv27=24
DIY INSTALL - THANK YOU LA_FX35:
https://www.infinitiscene.com/search/1/?q=13791-Unichip-Installation
ABOUT THE UNICHIP PROGRAMMER:
About this Manufacturer:
Wouldn't it be nice to add some noticeable horsepower, torque, and improved fuel economy to your car, truck, or SUV by simply plugging something in? Unichip makes that possible with its plug-and-play programmers, and each one is specifically tuned for the make and model of your vehicle in order to get the most gains with the least amount of effort possible. Installation is as easy and plugging the unit into your factory ECU and harness - that's it! This is probably going to be the easiest horsepower you'll ever come across… An added benefit to this method of tuning is that the programmer can be removed just as quickly as it was installed, leaving absolutely no trace that it was ever in your ride.
About this Product:
TESTED PERFORMANCE
Unichip's development for every vehicle involves demanding testing on the dyno, as well as in the field in a variety of environmental conditions and elevations
UP TO 30% MORE POWER
The Unichip releases more power from your engine, taking advantage of what stock and aftermarket components leave behind.
SMOOTHER PERFORMANCE
The Unichip's software is crafted to your specific engine, adding power where available and smoothing out the RPM curve for more power across the entire band.
MAXIMIZE THE POTENTIAL
The Unichip is engineered to maximize the potential of aftermarket add-ons such as Cold Air Intakes, Turbos, Superchargers or Exhaust Systems.
PLUG N' PLAY CONNECTORS
The Unichip uses custom-manufactured OEM connectors to connect the piggyback processor with the factory OEM computer. The Unichip Automotive Piggyback Module works in conjunction with the Engine Management System already fitted to most modern diesel & petrol engines. You simply unplug the original ECU wiring & install/plug in the highly developed pre-programmed Unichip Computer between the male & female plugs. All the necessary plugs are included in the harness enables this installation without cutting or intercepting the original wiring.
INVISIBLE INSTALLATION
The Unichip installs leaving absolutely NO FOOTPRINT - meaning its completely invisible to factory diagnostic tools.
FLUX DISPLAY (optional)
For some vehicles, the Unichip programmer is available with the Flux Power display for an extra charge (our product listing will say "includes Flux Power display" in the product name if it is included). The Flux Power display allows you to know your true engine performance. When installed with a Unichip programmer, it displays real-time power data, measures acceleration times, and even offers a virtual dyno!
PRICE:
MSRP: $1,000.50
FLASHTECH LED HALOS
http://www.kosokustomz.com/#!our-store/vstc3=exterior/productsstackergalleryv26=3
Most Advanced HALO Lighting System Ever Designed
Flashtech Led Halos combine the aesthetic look of Halo headlights with cutting edge LED Technology. Perfectly measured LED light rings filled with the highest end LED’s illuminate the area surround each reflector or projector in your headlight. This mimics the high end look of Audi’s and BMW’s without having to change your ride!
These Led Halos replace old technology such as CCFL with a much brighter and reliable product. Enhancing your cars or trucks lighting with a look that is unique and reliable is the only way to upgrade your vehicles lighting. Over a year of research and development has allowed us to receive Patent Pending status with the US patent office!
[TABLE="width: 407"]
[TR]
[TD="class: redtext, width: 206"]Flashtech patent pending LED Halos
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[TD="width: 1, bgcolor: #000000"][/TD]
[TD="width: 200"]Competitors CCFL Halo[/TD]
[/TR]
[TR]
[TD]• No power inverter or ballast needed.Can be hooked directly to any 12v source
• Made out of durable material
• Specifically designed for each vehicle
• Brightest Halo available
[/TD]
[TD]• Prone to failure. power inverter is needed to power on the halos
• Made out of glass and can break easily
• Generic sizes with poor fitment
• Less then ½ as bright as LED HALO[/TD]
[/TR]
[/TABLE]
Conversion Kit
Flashtech LED HALO kit allows you to upgrade your existing factory headlights with our Patent Pending Led Halo technology. This is a cost effect way to add the latest automotive lighting accessory to your vehicle without having to upgrade the entire assembly.
Kit contents:
Complete set of Patent Pending LED HALO Rings - Total 4 Rings for High and Low Beam
Appropriate mounting adhesive
Appropriate wiring and connectors
Installation instructions
Don't want to mess with the install?
Complete Headlight
Flashtech Led Halos can be purchased already assembled inside of a new factory headlight. This allows for a simple replacement of your current headlights with a new headlight assembly. Perfect for customizing or replacement of damage headlight assemblies
Complete Headlight Contents:
2 factory headlight assemblies
Complete set of Patent Pending LED HALO Rings pre installed
Prewired for your convenience
Colors:
Flashtech Led Halos come in a wide range of colors. From 6000k and 10000k in our white colors to the complete opposite spectrum with the ultraviolet PURPLE Halos. This allows complete customization for every customer needs!
Color List:View attachment 251618
6000k – Warm white - 10000k- Cool white
Yellow - Amber - Red - Blue - Green - Purple
Built in mounting brackets
Dodge Charger Kit:
PRICING:
Retail $199.99
BC FORGED WHEELS:
http://www.kosokustomz.com/#!our-store/vstc3=wheels-tires
FA02:
HB04:
TA01:
TA02:
TA08:
TA07:
TA04:
ST14:
ST12:
ST08:
RA07:
iFORGED WHEELS:
XTREAM LIP LINE:
TURISMO:
FABULOUS:
MONZA:
AVUS:
VIP LINE:
TRIUMPH:
LIMITED:
FABULOUS:
CONCAVE:
MILANO:
LEGACY:
INSITE:
FUSION:
EQUIP:
AEGIS:
** EACH WHEEL IS CUSTOM MADE TO ORDER, PLEASE PM US FOR PRICING AND FITMENT. CUSTOM COLOR'S AND COLOR MATCHING IS AVAILABLE
LIGHT WEIGHT PULLEY SET:
http://www.kosokustomz.com/#!our-store/vstc3=engine/productsstackergalleryv27=12
INCLUDES:
CRANK, IDLER, ALTERNATOR
Applications:2003-2006 Nissan 350Z 3.5L2003-2006 Infiniti G35 Sedan 3.5L2003-2007 Infiniti G35 Coupe 3.5L2003-2007.5 Infiniti FX35 3.5L (Single Throttle Body)
Kit Includes 3 Pulleys:- Crank- Alternator- Idler
OEM Pulley Weight: 7.56lbsSTILLEN Pulley Weight: 1.91lbsNON-UNDER-DRIVE - STANDARD SIZE, UNDER-DRIVE AVAILABLE
INSTALL MANUAL:http://www.stillen.com/product_files/400336~inst.pdf_
STILLEN HEADERS:
http://www.kosokustomz.com/#!our-store/vstc3=engine/productsstackergalleryv27=17
Fits On:
03-08 FX35 (Not For Dual Intake 08)
If ever there was a company known for its illustrious history in motorsports of all types, it's Stillen. Owners Steve Millen and David Schollum have had more than four decades of racing experience, from Formula and GT to stadium off-road racing, and have built Stillen to be a worldwide leader in aftermarket performance parts and accessories for cars, trucks, and SUVs. From mild to wild, Stillen makes products that will have your ride standing apart from, and ahead of, the pack.
About this Product:
The equal length design of these Stillen headers allows better and more efficient exhaust scavenging which contributes to the performance gains tested on the dyno, 11.5 hp at @ 6200 RPM and 18.5-lb.ft @ 3800 RPM at the wheels. With Stillen's 18 years of experience in designing and manufacturing Nissan performance parts, you should have complete confidence that every Stillen product is of the highest quality and has under gone extensive research and development before production. These hand crafted shorty headers do not require the removal of the catalytic convertors and are available in two versions; 100% Stainless Steel or Ceramic Coated Mild Steel both are Manufactured by Stillen. This part # is the Ceramic Coated Mild Steel Headers. Installation should be done by a qualified mechanic with proper tools and a lift. This is not a backyard bolt on. For the Stainless Steel Headers see part # 508380S. These headers do not remove the cats, but are not 50 state legal, check your area's regulations.
__________________________________________________ __________________________________________________ ________
ARK PERFORMANCE EXHAUST SYSTEM:
FITMENT:
09+ INFINTI FX35
[video=youtube;Roj150OpkNw]http://www.youtube.com/watch?feature=player_embedded&v=Roj150OpkNw[/video]
PICTURES SUPPLIED BY MRLERRY:
INTRODUCTORY PRICING:
MSRP: 1799.99
**** LIMITED PRICING ONLY! CONTACT US FOR THE BEST PRICING!
[video=youtube;iRartMaa2q8]http://www.youtube.com/watch?v=iRartMaa2q8&list=UUJlCw-ejA64Pv-jWdzyZF0Q&index=1&feature=plcp[/video]
PRICE:
INCLUDED:
2x HID Bulbs
Bulb Sizes:
3000K Color:
FITMENT:
Item No.:HS03IFXGIS
Piping Dia.:60mm
Tip Dia.:101mm
PRICE:
MSRP: $1300.00
FX35 PROGRAMMER:
FX45 PROGRAMMER:
About this Product:
TESTED PERFORMANCE
PRICE:
MSRP: $1,000.50
FLASHTECH LED HALOS
[TR]
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
Conversion Kit
Kit contents:
Complete Headlight
Colors:
Dodge Charger Kit:
PRICING:
Retail $199.99
BC FORGED WHEELS:
FA02:
HB04:
TA01:
TA02:
TA08:
TA07:
TA04:
ST14:
ST12:
ST08:
RA07:
iFORGED WHEELS:
XTREAM LIP LINE:
TURISMO:
FABULOUS:
MONZA:
AVUS:
VIP LINE:
TRIUMPH:
LIMITED:
FABULOUS:
CONCAVE:
MILANO:
LEGACY:
INSITE:
FUSION:
EQUIP:
AEGIS:
INCLUDES:
STILLEN HEADERS:
Fits On:
About this Product:
FITMENT:
09+ INFINTI FX35
MSRP: 1799.99
