neeeedddddd helllppp guysss pllsss
nyc5jabifx
ny queens
ok well whenever i clean my car or i mean everytime u see carefully theres tiny light scratches alll over the entire car paint i dont understand wat to do ...because i dunt anything about detailing ...is it from car washes??? what do you guys think i should do go 2 the detail shop?? wat is claying or wax ??? thanx theses are the scratches u seee u cant relly see em here 2997008443_ddbde411b1.jpg2997849108_779ce58ab6.jpg
thanxxxxxxxxxxxx
It's normal. It only shows up on dark colors. I have a black FX and to get them off you need to buff it.
soooo its normal wen its clean its shiny but the scratches kills it soo wat is buff??? how do i do it??? theres any other way how bout a deatil shop??? anything else clay//??
You can buff it out yourself or you can have a detail shop do it for you.
Someone tried this and had success. Although it was a different case but it still was a OB color FX.
Construction Problem.. :x - InfinitiScene.com
its normal if you are average joe car owner
its not normal if you are car detailing enthusist...... swirls are caused by mostly dirty washing equpiment that have been contaminated by contact with dirty surfaces such as the ground or a dirty work table where the wash mitts or towels can pick up sand/dirt/rock particles which would then come in contact with the paint when you wash the car....they also are caused by insufficient soap which then lacks lubrication to lift the dirt off your car with minimal scratching.... I wash my wash mitts in the washing machine everytime I wash my car.... I have like 4 or 5 so I have like a bucket of used wash mitts that I wash all at once..... I also use quality car soap like Meguiar's NXT car wash....2 buckets of water is prefered(one for soap one for rinsing mitt)..... use seperate mitt for rims and bottom side of bumpers and exhaust tips....always hand dry with fresh clean towel to avoid water spots....
when using car on regular basis.... avoid all contact with the paint.... dont lean against the car....dont close the door by pushing on painted surfaces(use door handle)....dont let your crazy friends near your car..... dont attempt to clean off bird droppings with anything other than a proper car wash or a detailer spray+quality microfiber cloth....don't put any object on painted surfaces....don't park near sprinklers....don't hose down your car.....wash every week to avoid build up of contamination.....
to remove swirl/scratchs..... use paint cleaner applied with hand or polisher(never use 10" orbitals) dual action polishers are prefered for beginners if buffing by machine to have minimal risk of misuse.....rotary buffers are for educated experianced users only....
protect finish with quality wax....
never use turtle wax products especially rubbing compound...... colored waxes dont work....nufinish is very harsh on paint..... no wax last 6 months under realistic conditions(longest is probably 2 months or 3)....dealer paint protection coatins are a scam..... teflon does not work as wax because it is heat activated at temperatures that would not be possible on automotive paint.....
You should dry it with wax-as-u-dry spray applied on wet with a cow hide cloth. It will leave ur FX spotless. I use it on my black FX. And make sure the cow hide is moist by soaking it in water then twist it up to make it soft. No homo.:laugh:
wow you know alot about detailing:smile: you should help me detail my car. Btw u have a Nissan Murano? I guess the ppl in the Nissan forum weren't as cool as us in the FX forums xD. Well technically the Murano is an FX with different styling but same everything and a quiet exhaust system.
As Doc said, technically it's not. FX is based on 350Z platform and Murano is based on Sentra platform. Nothing common except some brakes (03-05) and electronics
true the i was about 2 buy the murano but its based same as the maxima platform and after haveing 2 fwd cars acura tl and maxima didnt want another one rwd is more fun
