more spacer question
threezero
Vansterdam
I try searching and couldn't find anything.. maybe i wasn't using the right terms.
Just wondering how will the driving dynamic change if i ran 20mm spacer on the front and none on the back with stock rims?? would it affect performance on the snow? Any effect other than weirdness?
My summer wheels need spacer on the front but not the back. I do not want to purchase a second set for the back as winter is usually short. Also would like to avoid having to put on and take off spacer every year...
Are you running the OE whells in the winter ? If so just put spacer on the front and back and leave them on with the OE's.
Will running the spacers on the rear set your summer wheels set your offset out too far? As long as there are no rub issues I would just run all 4 with spacers.
Yes it will stick out too far :(
so i have stock 20's on my 09 fx35 but as you can see in the picture they are way to in the fender! how much (mm) Spacer should i buy so it could be flush with my fender?!? and is it safe to put spacers lol i really don't know! :P
Take a ruler and measure the distance between your tire and the outer fender lip.. That will give you an idea of what you'll need.
Three: you've got gtr wheels right? Is the front tucked in a lot? I know the back sticks out an inch or so.
Meant threezero bubito lol
