So my research into gauges has just begun and I thought it would be good to actually have a thread that talks about all the different systems out there and what the most common monitoring displays should have.
Already there have been a couple of suggestions in my turbo build thread, so I have cut & pasted them here:
Universal, expandable setups that have been suggested:
http://www.zeitronix.com/
http://www.hksusa.com/products/more.asp?id=3471
http://www.egauges.com/Defi/dp_top.html
I have identified the items that I want to monitor but I am still not sure where the gauges will be mounted and what they will look like. I'm thinking SMALL. If anybody has links to small gauges - from 1 inch to 1.5 inch digital displays - please post up. I think I'm leaning towards individual gauges rather than a universal display:
Oil pressure
Water Temperature
A/F
Boost
Transmission temp
I have seen some gauges that display multiple items as well - with the ability to display of two or three of the items above on one gauge all at once or selectable with a button.
Here is my shop's recommendation:
"AF gauges are nice but only truly useful under WOT for critical monitoring, otherwise they are always in a state of flux. Oil pressure and water temp is always useful data especially when the motor is cold - to monitor oil pressure vs. motor rpm. So when limited to two and knowing the Haltech sees its own wide-band, I prioritize two gauges differently.
The zeitronix display is likely a OBDII pass through tool that displays that data then pipes in it's own wide-band. Currently the Haltech will see all of it's own sensors which can be viewed in the software (read: your laptop), the next option from Haltech is they use Racepack and AIM dash setups which plug in native to the Haltech ECU. These are far from a simple gauge though and are generally meant to replace everything in a car to act as a new digital dash.
This all being said, once Haltech finds a new maker for there gauges themselves (used to be Nordschief or something like that but that went under about a year ago), you'll be able to buy a standalone gauge and wick the signal from your Haltech wide-band so that the same sensor feeds the standalone gauge and the Haltech ecu."
I have seen the Racepack display before and it is sweet, but doesn't fit with the theme of the interior. I want it to look like it belongs there. Here are two options from Racepack:
http://www.racepak.com/Components/Dash_Compare.php
http://www.aimsports.com/auto/index.html
Really I'm wide open to anything as long as the new gauges look like they belong. I'd consider mounting anywhere - on the roof liner, dash, on the console, hidden, pop-up, etc. Only thing that is non-negotiable is the aesthetic. They MUST match the amber OE gauges or interior.
Oil pressure
Water Temperature
A/F
Boost
Transmission temp
