jl subs
Any class D amp would work for those. JL is a good company; you're also going to need wiring and a way to get signal to those subs, so keep that in mind. None of it's hard.
So I bought the jl xd 600/1 amp and was wondering what amp wiring kit do I need the sales person was trying to give me a kit I dont know the specs but it was almost 400 dollars which sounded way too much.
That amp might be a little too powerful for those subs but you can keep the gain down and headroom is good. Not sure how underrated those subs are but jl says no more then 200 watts each. did you buy the subs yet
---------- Post added at 05:42 PM ---------- Previous post was at 05:31 PM ----------
all you need is a 4 awg kit like this. http://www.woofersetc.com/p-7427-xd...etawire-power-amplifier-installation-kit.aspx
---------- Post added at 05:46 PM ---------- Previous post was at 05:42 PM ----------
or even this. Ths company makes great wire. http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4
This is what over powering a sub will do
This was 1 10W6 powerd by a JL 500/1
Actually that wasn't from overpowering (technically) but a clipped signal.The 10w6 can eaily handle 500 watts rms but when you turn the gain all the way up it sends a clipped signal which can double the power of the amp and blow the sub. If the gains were set properly that amp would have never blown that sub
---------- Post added at 09:46 AM ---------- Previous post was at 09:44 AM ----------
But Jefferson is correct, that's what a blown sub looks like sometimes
It was probably my bad, I was using that amp for 4 10wv2 subs in my QX4
and I put it from there into the FX without changing any settings on the amp
Okay thats good im always lazy to exchange or return things haha, now I have to learn how to set the knobs on the amp properly. Im from hamilton, ontario by the way
I'm old school, i adjust by ear. Some adjust using a DMM. If you want to adjust by ear, turn the volume of the head unit to around 75% volume and slowly turn up the gain on the amp until you hear clippng, then turn the gain back a little and you're good. If that amp had a remote bass (gain) knob you can always set the gan a little higher on the amp but control the gain settng with the knob for different source. I find my radio doesn't play as loud as my cd player so i use the knob in my FX
I buy my audio from Radioactive in Burlington so if you need some one to help with the adjustments they are really good
I live in Milton
I should check out that place I'm a total noob when it comes to audio but I know I just want more bass. How do I know when its clipping? Also the installer said I need a high level input or something like that do I really need it? Hey were not to far from each other haha
