Invidia exhaust for FX50s
HP_FX50s
Toronto
Gordon from Invidia said the 2nd gen FX35 system should be release on may 20/2010..
Follow by that will be the FX50s system after testings.
For those who are looking for an exhaust system, as of now...i think Borla and Invidia are up to date with the 2nd gen FX.
Just recieved a set of 09+ FX35 Invidia system from Gordon. Going into my local MOD shop this friday for test fit and dyno run on my FX50s. Crossing my fingers....:wub:
Awesome guys!
I can't wait to see (and hear) the results, I would love to get this exhaust on my 50.
Hurry up Friday!!
Hey where are you located in NS, I was just there for the past week. I put over 5,000 kms on since I left home in Ontario on June 6th on my trip out east.
We stayed in Port Hastings, Sydney, Cheticamp and Truro this past week.
I got so many props about the FX there.
Can't wait 'til one of you crazy Canucks posts some video/sound clips...hurry up for God sakes...I need to mod this thing! By the way..just completed a road trip yesterday in the U.S. on the old historic Route 66! Any of you guys old enough to remember the old TV show? Anyways, the Nav saved my bacon more than a few times...except for one 3 hour detour through backwoods Oklahoma where the picture on the screen showed no roads at all! The FX50 is the perfect long distance road trip car! Now if only someone else could hear me coming!
Here's are the numbers put out at the wheels on my FX50s. The dyno and installation was done by "Magnus motorsport" in my area. The installation did not go as smooth as i was hoping for..after some cutting, grinding and welding, we wemade it fit. The numbers i got out of it was amazing. Couldnt be more happier. Thanx Gordon for hooking me up and letting me be the "first FX50 with invidia system"..The green was before putting on the Invidia 09+ cat back. The blue is after installed.
Stock tips
Invidia tips
Really gained in the upper RPM's! Torque is still the same, but it got a nice shift to the right. Must feel great right at 4500 RPM's when the power kicks in.
Fitment was not perfect. Everything was good but onced the x pipe was installed..we noticed the heat shield rubbing agaisnt it..we did not want to dispose the shield completely so cuttted down to half size so that its still there to protect the u-joint front the driveshaft.The last pipes before the mufflers were too long and the hangars did not line up with the mounts. We had to cut 2 parts and disposed about 3" total from each pipe and re-welded them to fit. After we shorten down the pipes and fitted to the x pipe and mufflers, the hangars lined up with the mounts.
This system has a really clean sound. It sounds as quiet as the stock when im coasting and light on the throttle. But once i punch on the gas pedal...it has a nice deep sound.
Video sound clip coming soon....
WOW! That sounds amazing!
I'm curious now if Gordon is going to relay the message back to the rest of the guys at Invidia and make the necessary changes to have the Invidia exhaust for the FX50 fit as a bolt on cat back instead of a custom cat back.
Aside from that, I do have to say that the dyno results are quite astounding. Good job to all the guys at Invidia!
