Hitch question
Yes. But if you are buying used make sure you get ALL the parts. There is the hitch itself plus a small bracket adapter and 2 parts to the wiring harness that consist of the harness itself and the relay that is located under the spare tire compartment.
Most get a Kurt hitch because of the lower price than the preferred OEM for best tucked away looks. Kurt, Uhaul, Reese, and Draw Tight all hang a little lower and show more than OEM. Receiver size is a consideration. If using for a bike rack, the wire harness is not needed for trailer lights.
