HID Fogs, Just got em..
solekeeper
South Fla.
Hey guys, I just received my hid fogs..
I went ahead and connected everything, w/o looking at the manual or anything.. (lol hard stuff i know)
Anyway, this is the set-up I got.
Is this right?
I just realized that the plug on the Bottom.. thats wrapped.. is not needed.. correct?
The part I connected it to goes to the OEM plug right?Thanks!
One person (sorry forget who it was) found the wire was necessary....they said it was not an extension. I honestly can't remember if I used it or not.
You really do not need to disconnect the battery...that is done as a safety precaution. It is wiser to disconnect it though...just in case.
The bottom wire is an extension that plugs into your stock positive/negative plug inside a HL housing. The kit seems to be made for custom jobs that is why there is a rubber grommet. Since you are installing these on fogs I believe you can remove the extension, and cut off the grommet. The bulb goes to the fog housing, and your positive/negative factory wires will connect to the bottom plug minus the extension.
Sorry if that confused you more.
