Help! on Wheel specs
Wuufer001
TX
came across a member selling a set of wheels including tires
i'm not sure of the brand of the wheel itself as i'm not familiar with this brand
also, the specs are 22x9.5 ET35 all round and 265/40/22 tires,
will have any problems running them and will the oem tpms fit?
i'm really interested in these for a temporary fix to switch out my OEM 18"s
will there be any difference in the diameter of the wheel? i actually don't want the car to sit higher than it is now already
the actual link is:
https://www.infinitiscene.com/search/1/?q=vbclassified.php?do=ad&id=733
any feedback is greatly appreciated,
TIA
The difference in tire diameter is 0.1" so the car will sit "lower" with the 265/40R22 tires.
They will fit and the size is right being close to OEM so you don't have to worry about odometer errors. The wheels will stick out 15 mm farther than the ones you have.
I'm not sure about TPMS but i don't see why they would not work with other wheels.
You should not have any problems.. Wheel/tire will be tucked in a bit, but poke out more than oem.. If you like the wheels, then go for it..
just realized i need to get hub centric rings which i'm totally blank about it, don't even know how it works or what size needed or even if it's safe enough:eek.:
night need to google more of it now:nerd (2):
You need to find out what the hub bore of the wheel is. If it's let's say 79.1 mm, you need a 79.1mm to 66.1 mm (which is your hub bore).
Therefore, there is no space between the wheel and the hub.
i actually have found another set with below specs.
20*10.5 et43 w/ 294/45/20 tires, square setup
have computed (using OEM 18" with et50) and it showed i have 18mm less on the strut side and 32mm extension on the fender side. will this be a problem with rubbing?
