Hello Everybody
twanger
St Charles
Im new to the infinity scene.
I just bought my first FX45 its an O# with 87 0000 miles
1 owner car
lots of service records. I see that there were a lot of fluid changes both diffs. case brakes were flushed coolant flushed as well
I changed oil and filter- Air filter and Cabin filter - Changing the plugs next weekend. What is best It has less exspencive NGK the OEM NGK in the car Or should I put Dens o plugs in it
What else do I need to Change?
Fluids
I'm considering changing the coolant and rear diff fluids too. Sounds like a mess but I'll have the right fluid in there.
Does the plastic engine belly pan have to be removed to get at the radiator drain plug?
Looks like I need a 10mm hex wrench for the diff plugs?
Thanks,
Bob
