Hazy Front Camera View
vmatador
Los Angeles
My front camera is now showing a hazy view whenever I use it day or night. Any idea what might be causing this? Is there a setting to correct it? How does your cam's view look to you?
Mine is clear as can be day and night:
Maybe the lens on your got damaged from road debris on the front or maybe it just needs cleaned?
Thanks for sharing! I cleaned the lens well, but the issue persists. The issue is with any light source (headlights, taillights, light poles, etc) in front of the car and it gets worse when my headlights are on. Objects that do not emit light or do not reflect light well appear just fine.
I had something similar happen about 6 months ago to my front camera. The seal on the lens either broke or wore out early and moisture got in there. You are possibly seeing a moisture haze. They replaced mine under warranty ($600) so I didn't have to pay anything. You might check with your dealer and see if you have the same issue.
