GTR wheels on my 09 FX35
Oh man, thank you guys for the quick responses!
I don't plan on lowering...at least not anytime soon. It will be at stock height for a while. With that said, it sounds like I need to get some 10mm spacers up front?
---------- Post added at 10:56 AM ---------- Previous post was at 10:53 AM ----------
No, you're not going to have an issue w/ turning. I would worry more about rubbing. 295 is pretty wide and 10.5" wheel in front at +25 offset is a little aggressive. No problem if stock height, but if you start lowering, may rub a bit.
Would going 285 be a smarter decision?
Probably, but either should work if you don't lower too much. And depending on the tire brand, 285 may be bigger than 295. Don't get the spacers until you test fit. The reason you may need spacers is that w/ a 10.5" wheel, you may make contact with the strut since it's wide. But if that isn't happening, no need for spacers unless you want it to poke out.
:plus1:
I'm on the search for some tires. I've learned that you can't always get the height with the width you want. I was thinking 285/45r20, but that doesn't exist. So, for anyone that has a 20x10.5 square setup...what tires are you using?
BTW...here's what i've found available as far as sizes go.
Discount Tire
285/40r20
285/50r20
295/40r20
295/45r20
Goodyear
285/50r20
285/40r20
295/40r20
did it lower the FX at when you switched over to the 20 inch GTR wheels?
I like mine high.
