Lucky! My tracking shows nothing has changed.
Same here.
Same here.
USPS is cheap!.... but slowwwwwwwww Sorry for the wait guys
Recieved my order today![]()
Don't be alarmed USPS tracking is just like that. They will likely show no progress, then show "delivered" the day after you receive it.
Ummmm...so what does that mean for my 2006 TL?
I believe for the 2006 TL, there is no existing Daytime Running Lights. So you would not need a module.
Hey guys so I received the bulbs and tried installing them but they won't light up. The bulb base looks just like the turn signal bulbs (only two prongs). When I plugged the oem dtrl bulbs to the turn signal it lit and when I plugged the LEDs into the turn signal they work but not when I put it in in the dtrl slot.
I once read that you can modify the base to make it work but can someone help me out here?
Sent from my ADR6300
Hey JLC Are those modules like HID Ballast? Them are Huge
You flipped them too right? I remember something about they don't work one way, but if you rotate them they do. Or maybe a blown fuse?I tried bending them backwards and made sure that the wires are in contact with the connector in both configurations (original position & bent back) but nothing worked. If anyone else gets it to with, please let me know!
Thanks!
Biggest question is how did you get them already, if you're in VA!
