Working with a local G owner here in town, we decided to develop an FX specific kit for much cheaper than is currently available. In the past he had grounding issues with older Nissans, and through extensive research into the platform grounding, he determined a simple four wire kit that takes care of the shortcomings he identified.
4 wires:
Battery negative to throttle body
Battery negative to Headlight ground 1
Headlight ground 1 to engine
Engine to Headlight ground 2
He's done many installs on both Gs and 350s with only positive or neutral feedback. I bought a kit he made for the G and found that some of the lengths don't quite work for the FX engine bay. So the two of us decided to develop an FX specific kit - at least post the lengths for anybody that wants to make their own. If you want a kit from this guy, I can put you in touch - or organize a group buy.
The kits are great quality and come in any color you want since he covers each wire with tech-flex. I got a grey/carbon fiber color for my kit. Here's a photo, but keep in mind it is NOT installed according to directions because these cables don't reach to the intended areas. Obviously we'll test fit to my car before putting this kit out there.
Looking at all the threads in here on grounding kits, I noticed there are a lot more options for grounding locations. I wanted to ask the community which grounding locations should be standard as part of this kit? Please post and I'll include one or two more wires as standard for the FX in this kit.
1. Throttle Body
2. Headlight ground 1
3. Headlight ground 2
4. Engine
5. lower plenum?
6. transmission?
7. ECUs?
Finally, if any FX45 guys out there want in on this, you might have to send me the lengths specific to the 45 grounding locations.
4 wires:
1. Throttle Body
4. Engine
5. lower plenum?
6. transmission?
7. ECUs?
