Fitment on FX35??? 22x10.5 Niche Apex.
illestFX35
Los Angeles/Glendale
2010 FX35 RWD
How will these wheels fit on my car. Will i have no issues with the centercap etc? They are a 22x10.5 +20. Will they poke out a lot??? A little poke won't bother me. Any tire suggestions? Thinking of 285/35 or 285/40 to fill up te fenders a bit more. Do you think these tires will rub? Thanks!
They're going to look good, but may rub depending on ride height and tire size. If stock height or on springs, no worries unless you get a wide tire. And the center cap should be fine. The offset is usually added on the backpad which pushes the wheel out so you'll have more clearance there. The other guy who has clearance issues at +45 so all things being equal, you'd have another inch of clearance there.
