EliteCoatingsNY
- Plainview, NY
Introduction and Pricing Thread
*****All forum members receive 10% off for mentioning this ad*****
(Cannot be combined with any other offers)
Fast Turnaround Times- In stock colors typically 3-5 days and 1-2 weeks on non-stock powders. Color matching is also available if needed (Call for details). Rush Processing is Available for any order.
Check us out at:
WWW.EliteCoatingsNY.com
Elite Coatings NY
30 West Ames Court
Plainview, NY 11803
Email: info@elitecoatingsny.com
Phone # (516) 802-0035
Fax # (516) 584-6595
Business Hours:
Mon – Fri: 9am-6:30 pm
Sat: By Appointment
Sun: Closed
Also feel free to check out our gallery at:
http://www.elitecoatingsny.com/gallery
Here is a list of just some of the services we can offer you:
Powder Coating
Powder coating is a metal finishing process that offers a far more superior finish than alternative finishes like paint. Powder coat offers greater durability, impact resistance, and improved wear characteristics in comparison to other finishing options. In addition to the improved durability, powder coating is offered in a great variety of finishes. Finishes include the basic gloss, semi-gloss, and flat finishes to unique texture, wrinkle, hammer tone, and candy finishes. There are thousands of colors available to choose from and if a specific color is needed then custom color matches can be made to match. Powder coating also provides quick turnaround times as once it is cooled back to room temperature it is ready for use. Feel free to call or email us to discuss your needs and the options available to you.
Ceramic Coating
Ceramic Coating is a finishing option for high heat applications that has practical use in automotive industry. Ceramic coating can help to lower temperatures in the engine bay as well as prevent corrosion on parts exposed to high temperatures. Due to the lower temperatures in the engine bay horsepower gains up to 5% are not uncommon. Our ceramic coatings can handle temperatures from 1600 to 2000 degrees Fahrenheit, dependent upon the application. The lifetime of the parts ceramic coated are also increased due to the improved corrosion resistance and decreased stress from lower temperatures on the parts.
Polishing & CNC (Machining)
Polishing is a metal finishing solution that will leave your part with a reflective finish. Polishing uses a combination of abrasive compounds and a work wheel to bring a shine to the surface of the metal. Not only is it for aesthetics, but polishing serves a practical purpose as well. It helps remove oxidation and prevent further corrosion of your parts giving them a longer life expectancy.
Factory Rim Repair and Refinishing
If you ever hit a pot hole and bent a rim or accidentally brushed your rim against a curb? Don't pay for a new rim when it can be repaired and look like new? We handle the process from start to finish including removing and reinstalling the rim on the car and the mounting and balancing of your tires. Give us a call and we'll have you back on the road within 48 hours.
We all know the conditions of New York streets; Pot holes are everywhere! The cost of replacing a wheel is higher than fixing them. Let Elite Coatings NY repair your damaged wheels whether it be:
• Curbed Damaged Wheels
• Bent Wheels
• Warped Wheels
• Cracked Wheels
We also offer additional services like:
· Heat Transfer Coatings
· Tire Mounting and Balancing
· Media Blasting
· Part sales including RIMS, TIRES, and many other AUTO PARTS
Check us out at:
Elite Coatings NY
30 West Ames Court
Plainview, NY 11803
Business Hours:
Sat: By Appointment
Sun: Closed
Powder Coating
Ceramic Coating
• Bent Wheels
• Warped Wheels
• Cracked Wheels
· Media Blasting
